Browse Forums General Discussion Re: windows out of plumb by 5mm 6Jul 15, 2020 11:02 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: windows out of plumb by 5mm 10Jul 15, 2020 12:56 pm ECOECO How do you know they are out of plumb? Do sashes and panels operate freely? hi ECOECO, we measured them. we did that from the outside and inside window sills. so we measured right and left corners and middle, then we worked out the differences. at this stage, we don't have a chance to close and open all windows, but we noticed that the track sills for the panels to open and close is pretty dirty. so I think I will have to check them at my PCI walk after they cleaned the windows. Re: windows out of plumb by 5mm 11Jul 15, 2020 1:04 pm Inspection should be well before PCI. If major defects are found you can dispute practical completion has been reached. Any defects identified at PCI should just be cosmetic items like paint blemishes and can be fixed quickly later before handover. Things you can see for yourself. I used Houspect. Their report was detailed. I accompanied them on the inspection and ensured as much as possible was checked. I learnt from the inspector and the NSDFT guide, then spent time onsite later carefully inspecting everything. Missed one small window not square, however! Re: windows out of plumb by 5mm 12Jul 15, 2020 2:10 pm Jo11 by the way, how do i move the question to the right forum? i can't seem to find way to do that, thanks You could report your own post and ask for it to be moved but ECOECO, the resident windows expert, has now seen this thread and posted replies. Probably still worthwhile asking for a transfer later to assist others who later search the Windows & Doors sub forum looking for a topic of importance to them. This thread has a good descriptive title. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. 4 14876 Unless there is something in special conditions the builder does not have to give you timeline. If your demolition contractor has not removed Asbestos and it was found… 12 29173 Thanks for the informative response! I'll feed that back to the site supervisor. 2 4280 |
