Browse Forums Home Finance Re: Question Reg FHOG 3Jul 13, 2020 1:23 pm plc That sounds a bit weird. As its your money it is above and beyond the loan. Unless they did a drawdown and then released the money into your account? What happened to the other $3K in FHOG? Cheers, Tom Thanks. Had to call in a couple of times to get this fixed. The FHOG was approved but sitting in some ghost account, the lender credited to the construction facility finally. You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9980 I would say both styles you have pictured are steel. The lower chord of the first pic would be a massive lump if made using timber considering the size of the rafters. If… 1 6157 1 13128 |
