Browse Forums Building A New House Re: KDR complications 7Jul 03, 2020 9:26 am One of my friends in our street did a KDR to subdivide and build 2 dwellings (sell one and live in the other). All 3 neighbors objected due to overlooking, shading etc, and the council rejected their application. They had several meetings with council (attended by the neighbours) and had to change their design several times, after which it was approved by council. One of the neighbors in particular was very difficult and unhappy with the result, but once approved they could go ahead and build All up the process took many months and cost them quite a bit due to delayed build and design changes, which they hadn't accounted for Re: KDR complications 8Jul 03, 2020 10:40 am Subdivision is a much more complicated process than just a straight knock down rebuild though. For our knock down rebuild (Wollongong Council) we did separate applications. The first was for approval to knock down, the second for approval to build.
In our case, the build was within the CDC specs, but as about 1sqm of our block (which was actually one the council verge) was classified a low flood risk area, we needed a DA. The neighbours weren't even notified by the council of the DA application being lodged. We did however, provide both neighbours with a copy of the plans at the same time as we lodged the application. We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37314 The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 19215 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 13542 |
