Browse Forums General Discussion Re: Floor Plan Advice 11Jun 26, 2020 6:42 am Thank you all for your input, obviously a newbie at all of this will have to sit down and have and rethink our plans. We are building with a project builder. Re: Floor Plan Advice 12Jun 26, 2020 7:04 am Given the space, you have the opportunity to improve orientation by changing the angle the house sits on the block. It doesnt need to sit in line with the boundary.
Id suggest you consider flipping the plan, and twisting the angle which will improve orientation immensely. It also gives you to opportunity to do some different landscaping options etc For this size house, I would be looking to include things like WIRS to bedrooms etc. The media room is odd, and the bathroom is ages away, may want to consider adding a PWD somewhere Re: Floor Plan Advice 13Jun 26, 2020 7:52 am Mattmartin We are building with a project builder. Given you are doing a project build, I would suggest you search for a plan that better suits your block and orientation from the start. That way you'll need to make fewer adjustments. Adjustments can add expense, as well as causing you to add extra decisions to a process that is already complex enough. As an extra piece of advice, the floor plan (the "plan view" of the design) is just one aspect of the complexity. If you come back to ask further advice, it helps to post the "elevation views" of the design too, as window and wall positioning, and roof design are important factors. Re: Floor Plan Advice 14Jun 26, 2020 8:01 am This is probably personal preference, but it looks to me like you have lots of rooms and 4 small separate living areas. If it was me I would be looking to have the main living area bigger, with more natural light and opening onto the alfresco. Yes, and echoing the other comments about the orientation... Re: Floor Plan Advice 15Jun 26, 2020 9:51 am Have a look at The Rural Building Company designs, and like others have said, use your space to optimise layout and landscape accordingly. There's nothing wrong with a garage door that doesn't face directly towards the road when you're on 3/4 of an acre... https://www.ruralbuilding.com.au/homes/ Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 26402 Hi there! Absolutely agree on the wasted space. We have no desire for the master to be that oversized, but it occurred when we increased the depth of the garage. We have… 4 14257 6 57546 |
