Browse Forums Kitchen Corner Re: Advice for a functional kitchen/scullery 5Jun 23, 2020 12:34 pm RobbieB94 mwarr Hi, I would 1 Lose the pantry as it will drive you crazy going in and out to put stuff onto the scullery bench for prep. Push wir in the bed into pantry for larger bedroom and then use the other side/half of pantry as IT nook or similar. 2 Switch out the swinging door for internal cavity slider to give more opening space. 3 Move sink to under window 4 Wrap bench around wall of pantry/wir/nook to gain more bench. 5 Open shelves above and below bench for easier acces than cupboard 6 Put cavity slider to laundry to shut out noise and visual mess. Just my 2 cents worth. Mike Can you show me what you mean? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice for a functional kitchen/scullery 6Jun 24, 2020 3:55 am mwarr RobbieB94 mwarr Hi, I would 1 Lose the pantry as it will drive you crazy going in and out to put stuff onto the scullery bench for prep. Push wir in the bed into pantry for larger bedroom and then use the other side/half of pantry as IT nook or similar. 2 Switch out the swinging door for internal cavity slider to give more opening space. 3 Move sink to under window 4 Wrap bench around wall of pantry/wir/nook to gain more bench. 5 Open shelves above and below bench for easier acces than cupboard 6 Put cavity slider to laundry to shut out noise and visual mess. Just my 2 cents worth. Mike Can you show me what you mean? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Similar to this? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Advice for a functional kitchen/scullery 9Jul 28, 2020 9:28 am There are a few things i would consider changing. 1) The Walk In linen at the front of the house to be deleted as it seems there is ample storage throughout the house and extend the WC to make a powder room with vanity and mirror. Remove Bed2 Robe and put in onto the back of the Bath tub Wall as the room is long to make the hallway area better with the larger WC and you could also lengthen the drop off zone recess to make the living look bigger 2) The kitchen Island looks too small and looks too far away from cooktop bench. The gap between the 2 benchs should be 1000 to 1200mm max. I would also extend the benchtop towards the doors leaving only a 600mm gap from bench to glass t give you more bench space in the front kitchen as it seems too small 3) If you are not having a water point behind your fridge I would change swinging door to a cavity door as this door will always be open and will be more practical. 4) Cavity slider to the Theatre Room as well as your Ensuite entrance 5) Bathroom would be best to swing bath to vanity wall so the window can be widened and allow plenty of light and the vanity switched to back onto Bed2 Hi, We're building a double-storey in Perth and I'm undecided with the kitchen sink situation. I'm set on having the main sink with dishwasher in the scullery - and… 0 20891 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15443 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14299 |
