Browse Forums General Discussion Re: Steel Frame Price 2020 3Jun 23, 2020 1:52 am Thermally, steel frames only work if you insulate it from the outside or from the inside (e.g. with EPS/XPS) to prevent thermal bridging. In-stud insulation will never be effective enough to comply even with the minimum insulation requirements. How much does the double brick wall costs in Perth nowadays, I wonder? In NSW it will be roughly $160-180 for materials ($2 face bricks, $0.8 inner leaf breaks, rigid insulation between leaves, ties, mortar) + at least $100 for labour (if you are really lucky) + plastering/drywall costs separately on top. I would assume timber or steel frame + veneer brick should still be way cheaper to supply and install + you should also save something on "lighter" foundation requirements as well as on the reduced construction time. Re: Steel Frame Price 2020 4Jun 23, 2020 7:08 am Talk to Summit Homes. We are building Steel frame with them in Perth. They have ticked all my boxes all the way through. They believe it will be the future of house building in WA. Let me know if you want our sales guy contact, an absolute pro. Re: Steel Frame Price 2020 5Jul 07, 2020 10:20 pm mwarr Talk to Summit Homes. We are building Steel frame with them in Perth. They have ticked all my boxes all the way through. They believe it will be the future of house building in WA. Let me know if you want our sales guy contact, an absolute pro. Hi there, How far into your steel frame build are you with Summit? We are looking to build with them due to offering steel frame ( originally from QLD) double brick seems primitive to us. Any pointers you have to clear up with summit prior to signing of contract? Cheers Re: Steel Frame Price 2020 6Jul 08, 2020 7:52 am plainlandhouse mwarr Talk to Summit Homes. We are building Steel frame with them in Perth. They have ticked all my boxes all the way through. They believe it will be the future of house building in WA. Let me know if you want our sales guy contact, an absolute pro. Hi there, How far into your steel frame build are you with Summit? We are looking to build with them due to offering steel frame ( originally from QLD) double brick seems primitive to us. Any pointers you have to clear up with summit prior to signing of contract? Cheers Hi Should have plans submitted to council next week and sign about the same time. Summit have been awesome all the way through and in fact suggested we go steel frame based on our block and what we were wanting to achieve . Let me know if you want our guys contact details. Good luck Re: Steel Frame Price 2020 8Jul 09, 2020 8:54 pm Filipe Hi All, We're contemplating building our first home with steel frame for its advantages re passive heating and cooling. Er, a steel frame for it's passive design advantages? I think you've got that wrong. Steel, like all metals, has high thermal conductivity. This conduction of heat creates the issue of thermal bridging, heat traveling through your building envelope. Timber is an insulator, with far lower thermal conductivity than steel. It's a far better choice for a building's frame. It's also cheaper! If your interest in passive solar design is not just about energy efficiency to save on bills, but also about sustainability, then you'd be interested to know that timber, when harvested sustainably, is a far, far more sustainable choice. Steel has high embodied energy, meaning it's production creates large amounts of CO2 emissions. Timber does the exact opposite. It locks up CO2 in the home's structure! I guess you're a bit confused, comparing a double brick home, to a framed home, whether that's timber framed or steel framed. Whether it's brick veneer, reverse brick veneer, or lightweight cladding. It's not the steel frame that makes these more energy efficient. It's the room in the frame for higher levels of bulk insulation. Me, I'd choose a timber frame every day. For coastal areas I'd use lightweight cladding. With a concrete slab, ample thermal mass for thermal stability. For inland areas I'd consider upping the thermal mass with reverse brick veneer. I'd recommend you read the government's 'Your Home' website. Not just to learn more about passive design, but also this section about different building materials & techniques, https://www.yourhome.gov.au/materials/c ... on-systems Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14458 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8045 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4461 |
