Browse Forums Buying Land 1 Jun 17, 2020 1:55 am Follow my build: View topic - Dale Alcock - Custom 'Marlow' 2 Storey • Home Renovation & Building Forum (homeone.com.au) Re: Narrow Block - 7.5m Frontage - Hammond Park WA 5Jun 19, 2020 12:31 am Follow my build: View topic - Dale Alcock - Custom 'Marlow' 2 Storey • Home Renovation & Building Forum (homeone.com.au) Re: Narrow Block - 7.5m Frontage - Hammond Park WA 12Jun 19, 2020 3:05 pm You can fiddle with the details, but it won't make this design more livable in my opinion. It's a poorly designed space with unfurnishable living areas and no light. There are better 7.5m block designs out there so shop around. The block is too nice to waste on a design like this. Re: Narrow Block - 7.5m Frontage - Hammond Park WA 14Jun 19, 2020 6:19 pm Unfortunately with a cottage block of this size, that has the garage to the north and the views to the south there are going to be compromises. It's really up to Sal_sa_by to decide what is important and then rank them from not negotiable to less important so she can work out where the comprises will be made. Some of the things I can see that need to be decided. Double or single garage. Garage attached or separate. Living rooms taking northern light or southern views. Bedrooms all together or split. Laundry with direct access to outside or walk through house. Courtyards that access front or back or are built in. Total budget. Zoning (total allowed site cover) All those things will have a massive bearing on the final design and each thing may be more or less important to her. To give advice without knowing them is a bit futile. The design she has had prepared has compromises but so will every plan that can be built on that block. Those compromises may be quite acceptable for her, and there are several things to like about the plan. Any good designer should have explained some of those compromises with her and got an idea of what is and isn't important so she can get as close as possible to her dream home on that lot. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 4 4499 dimensions on your original plan are inconsistent and with accurate dimensions (including site plan, upstairs and down) i could make a proper scale drawing with furniture… 3 7520 Thanks again for this information. If you do hear anything different, would be great to know 4 8256 |
