Browse Forums General Discussion Re: Earthworks Perth Hills 5Jun 18, 2020 10:05 pm Typical footing on class A is 280 high 300 wide. 350mm below ground level minimum. If you need to bring in fill and compact that's fine, you just need to check if you will then need retaining walls. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Earthworks Perth Hills 7Jun 18, 2020 10:23 pm alexp79 AS 2870 specifies 400 mm deep footings for articulated masonry and 500 mm for full masonry on Class A (for rafted slabs). Waffle pods will be shallower, yes. Typical detail Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Earthworks Perth Hills 8Jun 18, 2020 10:33 pm So the total depth of internal beam is 450 mm on your drawing. But yes, if you place slab on top of the natural ground (although it would still require some smoothening), you would only need to excavate to around 350 mm deep. Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11015 Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 3646 I am not sure whether Perth has its own way of doing things in regards to this. Most of Perth has class A (sandy soil), except for some areas near rivers or hills. 2 13063 |
