Browse Forums General Discussion Re: Hole in kitchen wall - ideas needed! 2Jun 13, 2020 2:55 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Hole in kitchen wall - ideas needed! 4Jun 13, 2020 8:29 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Hole in kitchen wall - ideas needed! 7Jun 13, 2020 9:32 pm ajn Thanks for the quick advice. Really really helpful. Would you recommend using something like selleys filler around the edges for a smooth finish? Just butt the one side against the corner wall and overlap 50mm top and other side. Along the bottom I'd just cover the actual hole without much overlap just so you don't have to house out as much in the recess. Just screw and plug it to the wall and then gap fill with no more gaps around the edge so it's sealed up to prevent any creepy crawlies come in. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Hole in kitchen wall - ideas needed! 8Jun 13, 2020 9:45 pm alexp79 ideally I'd replace the tiles (I've been able to paint match pretty well with some ceramic tile paint) and have the MDF / FC board sitting above them. Do you think I'd need more than 3mm MDF? Trying to make sure I don't have too much jutting out from the wall so it looks neat for tenants coming in. Re: Hole in kitchen wall - ideas needed! 9Jun 13, 2020 10:05 pm Because of the way the plumbing has been run you will find it very hard to effect any flush finish. If you want to, you will need to frame or trim out the opening and then sheet it flush and then flush coat it in. Because of the tiles you will have to try and cut out the broken tile and put in something to level it up. To get a semi decent finish will cost you a decent amount. If you are going to renovate just neaten it up with a cover, you could always make the cover a small shelving unit. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4474 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 18864 Hi guys We have just removed a very large grape vine which was mounted to a structure along this wall. This is a shared wall with our neighbour, and after removal, we… 0 3960 |
