Browse Forums Building A New House Re: Building Costs - The 'price' realistic vs paper 2Jun 03, 2020 7:54 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Building Costs - The 'price' realistic vs paper 5Jun 03, 2020 8:33 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Building Costs - The 'price' realistic vs paper 13Jun 03, 2020 12:27 pm D350mh My build worked out to be approx $1,580.000 per square meter. The above looks to be in the ball park So thats with no landscaping/fencing, but legit everything in the house done, site costs, plans etc etc? Re: Building Costs - The 'price' realistic vs paper 15Jun 03, 2020 4:09 pm How does the tender process work? Can you get people you know to tender for work? I.e I know a sparky, can this reduce your cost. I dont want to take corners but if sparky A will charge me like 40k hypothetically, and sparky B will change me 37k for the same quality, and work, then im better off going for sparky B. Im assuming this process happens BEFORE contract signing and would incur some costs to get to this point? Re: Building Costs - The 'price' realistic vs paper 17Jun 03, 2020 4:26 pm Mintee How does the tender process work? Can you get people you know to tender for work? I.e I know a sparky, can this reduce your cost. I dont want to take corners but if sparky A will charge me like 40k hypothetically, and sparky B will change me 37k for the same quality, and work, then im better off going for sparky B. Im assuming this process happens BEFORE contract signing and would incur some costs to get to this point? where are you looking to build? Re: Building Costs - The 'price' realistic vs paper 19Jun 03, 2020 4:34 pm Mintee Fraser Rise - Most Likely Westwood Estate Find a building designer (not an architect) and design your own, then take it to a builder, if its a flat block you should be between $1300-$1550 per m2 (Sydney prices) Re: Building Costs - The 'price' realistic vs paper 20Jun 03, 2020 4:35 pm GrahamB Mintee Fraser Rise - Most Likely Westwood Estate Find a building designer (not an architect) and design your own, then take it to a builder, if its a flat block you should be between $1300-$1550 per m2 (Sydney prices) Ive been told a 350mm fall; i've been told this isn't 'crazy' or 'too bad' > 500mm is bad? When you say 'take it to a builder', like a local, non project builder? or do they build this too? Wow I hadn't realised things had gotten that pricey in just a couple of years since I built, that is crazy with how much land is now costing if you aren't lucky enough to… 3 7193 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35487 Just to makea point about this, an approach that some people have found sucessful in negotiating these rises down, Is to provide some workings to the builder, specifying… 4 81806 |
