Browse Forums Building A New House Re: Hebel Powerfloor insulation 3Oct 28, 2019 4:21 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Hebel Powerfloor insulation 10May 26, 2020 9:00 pm No the heat (air) is not absorbed by Hebel. The wall systems are better than Brick but you still require batts to bring to code. The introduction of Powerpanel XL was further evidence that really the Hebel system is just a basic "cladding", as the insulation brings it to code. Re: Hebel Powerfloor insulation 11May 26, 2020 9:11 pm Powerpanel just adds to insulation, it is not replacing completely replacing it, as it is quite thin. It performs better than brick though. However, if you build your house out of Hebel blocks, 300 mm will be enough to address insulation requirements of even colder areas such as Tasmania and ACT (in fact, even 200 mm should be enough if we count in thermal mass properties). No code defines insulation between the floors though. As insulator as well as thermal mass, Hebel will not be transferring heat, e.g. if you put it on fire, the inner layer of Hebel will be only few degrees warmer while the outer layer will be thousand degrees hot, e.g.: https://www.youtube.com/watch?v=ohKp3uoifqg 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 3660 I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 4843 1 5039 |
