Not a sound is heard downstairs from upstairs. It is very solid like stepping on the slab. I highly recommend it as
an alternative to chipboard flooring with its squeaking!
Did you use acoustic plaster for your ceilings as well?
Browse Forums Building A New House Re: Building the Metricon Doulton 287May 26, 2020 11:39 am stanus Macher stanus the hebel floor has probably been the best decision I made (apart from the 3 meters to the first floor) Not a sound is heard downstairs from upstairs. It is very solid like stepping on the slab. I highly recommend it as an alternative to chipboard flooring with its squeaking! That's a great review for hebel power floor. Too late for me but I can tell others of your positive experience. We just have to identify all creaks before handover and put in some premium underlay for upstairs carpet. That's all we can do for now. Did you use acoustic plaster for your ceilings as well? Macher I did not use acoustic plaster for the ceilings. when requesting the extras on the build I was very 2 dimensional and did not think of the ceilings. I am sure that covering the ceilings with soundstop would have doubled the cost of the wall soundstop plaster and that would have been just for the ground floor ceiling let alone first floor. One thing I have learnt from experience is outside noise comes mostly from the windows and it is there that you need to spend the money. Double glazing does help a bit, but in a perfect world multiple(3 or 4) thick panes would be better. Hi Stanus, in addion to the Hebel Powerfloor, did you also use acoustic bats between the levels? Trying to work out if I need from a thermal or noise perspective? My husband is concerned with using the PowerFloor only? Really appreciate your experience! Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10732 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8179 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17330 |
