Browse Forums DIY, Home Maintenance & Repair Re: Advice on Plumbing 2May 24, 2020 9:14 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Advice on Plumbing 3May 24, 2020 9:46 am SaveH2O mattscib I put a stake through a 100mm pvc pipe (right through) Top and bottom? Can you post a photo of the hole(s) next to a rule or similar that shows the size and any cracking additional to the hole(s)? Does the pipe have a flush outlet that will drain the sub surface pipe? Hi SaveH2O - yeah I put a stake through the pipe which damaged top and bottom of 100mm pipe. The damaged area is about 130mm long. Not sure what you mean with flush outlet? This pipe is connected directly to the vertical down water pipe. Re: Advice on Plumbing 4May 24, 2020 12:25 pm mattscib Not sure what you mean with flush outlet? A flush outlet allows water to flush out of the wet system but they are mostly above ground and so don't drain the underground pipe but I suppose that your pipe has lost a lot of water anyway. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ mattscib yeah I put a stake through the pipe which damaged top and bottom of 100mm pipe. The damaged area is about 130mm long. Ouch! Fernco advise a maximum working pressure of 4.3 psi which equates to a 3 metre head. The quickest and easiest way: 1. Buy two 100mm flexible couplings. 2. Cut out a section of the existing pipe then clean and de-burr the ends. 3. Cut a new section of 100mm DWV pipe to size. 4. Slide the two couplings over the existing pipe. 5. Mark a 'stop' distance on both ends of the new pipe and then slide both couplings over the new pipe to the 'stop' line and tighten. BTW, are you still having trouble with the rainheads? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Advice on Plumbing 5Jun 11, 2020 9:35 am Thanks for the advice, when I went to do the repair, the 100mm pipe was more like an oval. It was previously backfilled with a large rock squashing the pipe. Left it to the plumber who installed 4 x 90 degree elbows. With regards to the rain heads, we installed a gutter guard and I removed the first 10mm square screen, we haven't had issues since. Just a regular clean of the fine gauze material mat to prevent them from clogging up with leaves. In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6162 For anyone that comes across this issue in the future - Just did what aussieta said and found a plumber to inspect it and sign off on it. Was difficult to find someone to… 3 6988 5 3754 |
