Browse Forums General Discussion Re: How do I build this shelf? 2May 23, 2020 10:31 am The timber parts look easy enough, but the angled metal brackets would be a challenge to fabricate if you want them to look exactly the same. Do you want yours to be adjustable like that on, or are you willing to have the shelves fixed in place? Re: How do I build this shelf? 5May 25, 2020 8:38 am Evangiking ...not quite sure where to begin You need to go to a timber supplier (Bunnings is fine) and buy long upright pieces and also shelf timbers. It would be best if you could space the long uprights to exactly match studs in your wall (presuming you are fitting it on a stud wall), so that will set the width of your shelves. The timber supplier could cut everything to size for you. You also need to buy some (metal?) brackets with holes at both ends. Re: How do I build this shelf? 6May 25, 2020 4:26 pm luxbuild I just googled bookshelf brackets and there some that are similar. Thought that might help? Some good stuff came up, thank you! Re: How do I build this shelf? 7May 25, 2020 4:27 pm arcadelt Evangiking ...not quite sure where to begin You need to go to a timber supplier (Bunnings is fine) and buy long upright pieces and also shelf timbers. It would be best if you could space the long uprights to exactly match studs in your wall (presuming you are fitting it on a stud wall), so that will set the width of your shelves. The timber supplier could cut everything to size for you. You also need to buy some (metal?) brackets with holes at both ends. Thank you, I really appreciate the details Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17602 Hi, did you get any money from insurance? if you did, does it match what you've already paid the builders? 3 9565 Hi We have finally decided to complete a KDR on our corner plot in NE Melbourne suburbs. Given its a corner plot approx. 400 sqm just a standard design may not fit the… 0 8568 |
