Browse Forums Building A New House Re: Building a Metricon Glendale 42 Limited Edition in Melbo 592May 17, 2020 10:40 pm Our Bayside KDR Thread: viewtopic.php?f=31&t=78298 Re: Building a Metricon Glendale 42 Limited Edition in Melbo 594May 17, 2020 10:51 pm ![]() ![]() ![]() looking great - make sure that you inspect the brickwork before the brickies leave - the Moonshadow is a film face brick - i.e. it is a painted finish. If they've chipped them while laying them, they have to be fixed with touch-up paint or replaced, and it's heaps easier to get them replaced while they are still there Hi Drew01 would you know if it is ok to use film face brick i.e. a painted finish brick? What are the disadvantage of using this over brick which are coloured throughout? I am finding darker bricks like this, they mostly all painted like Austral Matallix Graphite or Industrial Char. Will the paint go off in few years, hard maintenance etc? Keep in mind, that dark bricks are currently on trend, but reds, browns and charcoal is a lot more timeless We made sure to identify any big chips that happened through the build and Metricon touched them all up. Re: Building a Metricon Glendale 42 Limited Edition in Melbo 595May 17, 2020 11:48 pm ![]() ![]() ![]() looking great - make sure that you inspect the brickwork before the brickies leave - the Moonshadow is a film face brick - i.e. it is a painted finish. If they've chipped them while laying them, they have to be fixed with touch-up paint or replaced, and it's heaps easier to get them replaced while they are still there Hi Drew01 would you know if it is ok to use film face brick i.e. a painted finish brick? What are the disadvantage of using this over brick which are coloured throughout? I am finding darker bricks like this, they mostly all painted like Austral Matallix Graphite or Industrial Char. Will the paint go off in few years, hard maintenance etc? The only issue with film face bricks is when they chip, it's generally red brick underneath, so you use a maintenance paint to touch them up. Not a massive deal, just a pain in the arse when it happens. Keep in mind, that dark bricks are currently on trend, but reds, browns and charcoal is a lot more timeless Thanks Drew01 Re: Building a Metricon Glendale 42 Limited Edition in Melbo 596May 17, 2020 11:50 pm Thanks shokel1975 I am assuming then you used Selkirk Moonshadow? Are you able to share a final closeup photo of your house to display the brickwork. thanks in advance. Building a Metricon Glendale 42 Limited Edition in Melbourne 597May 17, 2020 11:59 pm [quote="idev":32u9gowp]Thanks shokel1975 I am assuming then you used Selkirk Moonshadow? Are you able to share a final closeup photo of your house to display the brickwork. thanks in advance.[/quote:32u9gowp] Yep, we were a little concerned about using them but we were told to ensure tradies don’t use a strong acid wash on them when cleaning the bricks. Our SS assured us they don’t. They turned out pretty good with only minimal chips to touch up. Here are some pics... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building a Metricon Glendale 42 Limited Edition in Melbo 598May 18, 2020 9:39 am Looks very distinctive and striking shokel1975 ![]() Re: Building a Metricon Glendale 42 Limited Edition in Melbo 600May 18, 2020 10:14 am Thanks @shokel1975 Get a licenced carpenter or roofer for the roof and structural work and do all the rest your self. If you need a building permit then get that too and just get the trades… 3 2507 I am currently planning for (designing) a ground/surface level drainage design at my property. I am based… 0 293 You quickly learn who the best are in their fields and hope the standard is repeated ,too good for the industry to loose. 2 807 |
