Browse Forums Building A New House Re: Needs helps with facade colour scheme 4May 14, 2020 10:31 pm The roof in all three is definitely monument (with 3rd pic potentially night sky). Window trims and gutters/fascia would also match in monument. However, fascia in 3rd pic appears to be surfmist. Garage door in second pic is surfmist with render on exterior in the same colour to match. Garage in 1st and 3rd is more custom and outside standard dulux colorbond garage doors. 3rd pic the render on the portico looks like dulux domino and around the garage appears to be stony creek or flooded gum (or something similar). Disclaimer: these are all educated assumptions based on standard colours that builders use on homes. Please do not take this as a guarantee. Re: Needs helps with facade colour scheme 5May 15, 2020 2:48 am Margin The roof in all three is definitely monument (with 3rd pic potentially night sky). Window trims and gutters/fascia would also match in monument. However, fascia in 3rd pic appears to be surfmist. Garage door in second pic is surfmist with render on exterior in the same colour to match. Garage in 1st and 3rd is more custom and outside standard dulux colorbond garage doors. 3rd pic the render on the portico looks like dulux domino and around the garage appears to be stony creek or flooded gum (or something similar). Disclaimer: these are all educated assumptions based on standard colours that builders use on homes. Please do not take this as a guarantee. Thanks so much this helps me so much. Just another question do builders do a garage door like the one in pic 3? Re: Needs helps with facade colour scheme 6May 15, 2020 5:06 pm Yes they do them, but likely to have a price increase in thousands. Ive just had a quote for fancy garage doors and they over $10K in comparison to standard doors of less than $5k, and that’s without a builders margin.. Re: Needs helps with facade colour scheme 7May 20, 2020 4:00 pm gogo65 Yes they do them, but likely to have a price increase in thousands. Ive just had a quote for fancy garage doors and they over $10K in comparison to standard doors of less than $5k, and that’s without a builders margin.. Wow 10k Now that’s unreasonable. Re: Needs helps with facade colour scheme 9May 20, 2020 8:34 pm gogo65 Not unreasonable, just the cost of the door! Like I said this was direct with the garage door company, so not even a builder upgrade, just the cost of the door... Maybe they are all different type because my sale rep told me if I wanted the one in the pic it was 5k to upgrade. Re: Needs helps with facade colour scheme 10May 20, 2020 10:59 pm I was saying the cost of the doors was $10k, standard doors about $5K, so an additional $5000, plus whatever your builder wants to charge you, My doors were were probably more expensive than the ones you pictured, but like I said the cost is in the thousands... I'm renovating - building a small extension at the back of the late Edwardian house. This is the first stage. Second stage of the renovation will be to replace roof on… 0 1085 Thank you @. Tried to play with the facade models but the exact colour is not matching up. 2 3258 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7496 |
