Browse Forums Building A New House Re: Floor Plan Design - Plumbing /Drainage/AC Issue? 3May 13, 2020 9:52 am Thanks alymei The main bathroom services bedroom 2 and the Rumpus on the second level. I was going to go with ensuites to all bedrooms (no main bathroom) but the kids wanted access to a tub but still did not want to share an everyday bathroom (which we can accept). Separation of the bedrooms was something on my criteria and seems to be general expectation on homes of this size (45 squares). Just seems to be a strange reasoning given there are many examples of similar positioning. Re: Floor Plan Design - Plumbing /Drainage/AC Issue? 4May 13, 2020 11:47 am I’m no expert but it seems you have a steel beam across the bottom of the downstairs and then a stacker door, looks like you may need a bulkhead across the steel beam for your waste, as it won’t be able to go straight through the wall cavity. Wile I can’t imagine accessing waste pipes through a bulkhead would be an issue, you would certainly need to consider it from an aesthetics point of view. Re: Floor Plan Design - Plumbing /Drainage/AC Issue? 5May 13, 2020 11:51 am One more comment (you may choose to ignore it!) you say this is a 45 square home, you seem to have bathrooms everywhere and then your laundry is smaller than your pantry! If you have that many people in your home that need all those bathrooms surely you need to consider the size of the laundry so you can wash all those towels!!! Re: Floor Plan Design - Plumbing /Drainage/AC Issue? 6May 13, 2020 12:34 pm gogo65 One more comment (you may choose to ignore it!) you say this is a 45 square home, you seem to have bathrooms everywhere and then your laundry is smaller than your pantry! If you have that many people in your home that need all those bathrooms surely you need to consider the size of the laundry so you can wash all those towels!!! I agree with what you are saying about the Laundry, I wanted it left larger but was voted down by wife and even the builder's rep. It was substituted with storage area which we also need. interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 47181 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17596 Hi, Seeking volume or semi-custom builder in victoria(east), which have existing double story wide floor plans. Seeking 18-20m wide homes with depth of 12-15m long. Or… 0 25424 |
