I don’t go anywhere without a camera…….I’m always taking photos these days of anything that catches my eye.
Put one in your car installation inspector, you will be glad you did.
Browse Forums Lighting + Lighting Design Re: Downlights 61Oct 17, 2008 6:13 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Downlights 63Oct 17, 2008 6:20 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Downlights 70May 10, 2020 2:08 am 3000K colour temperature is called ‘warm white’. This is traditionally a relaxing home colour although home lighting tastes are now changing. 4000K is called ‘cool white’. This is used in all offices and most shops. 5000K is called ‘day light’ and is common in factories, warehouses and outdoor flood lighting. Some people, particularly those living in, or whose heritage is from warmer climates, prefer 5000K or higher colour temperatures everywhere. Most home downlights have a slide switch on their backs to select 3000, 4000, 5000K. This is set at installation but is easily changed later by the homeowner. Brightness (Lumen output) is normally controlled with a dimmer control on the wall switch. All but the very cheapest of home downlights are capable of dimming from about 10% to 100% of brightness. With downlights another consideration often missed is the spread of their beams. Many cheap smooth faced downlights deliver a wide light beam which can be quite harsh and glarey, particularly in bedrooms or with 6 or more of them in living areas. Re: Downlights 71May 11, 2020 2:15 pm Scooter13 rantapawan Melbournevic We have two options either 5000K or 3000k both 10Watts LED. We will go for 5000k as we prefer brighter lights due to vision issues. Is this too much or just right? I don't think it is but I'm not sure. 5000k is too bright for household applications.. except when used for task lightings like in the kitchen or garage. 3000K or 5000K does not indicate the brightness of the light, its the kelvin rating or in simple terms the colour of the light..5000k will be a very “white” light where the 3000k will be more towards a halogen colour “orange” light which is softer and warmer in colour and better for living rooms etc..even 3000k leds are quite white in colour.. Actual brightness is measured in Lumens.. A light having a higher color temperature appears brighter. Re: Downlights 72May 11, 2020 2:39 pm Higher colour temperature LED lights are also a bit brighter than lower colour temperature lights with the same amount of input power. About 10-20% brighter, therefore they are more energy efficient which has an added benefit of reducing costs in industrial applications like warehouses. The reason is to deliver the warmer lower temperature colours the lights use a thicker coating layer of yellow or orange phosphorus material on the LED chips to convert the original blue/white light that LED chip emits to a warmer colour. This thicker phosphorus layer also blocks more of the light from getting out. Re: Downlights 73May 11, 2020 4:13 pm Norfolk Higher colour temperature LED lights are also a bit brighter than lower colour temperature lights with the same amount of input power. About 10-20% brighter, therefore they are more energy efficient which has an added benefit of reducing costs in industrial applications like warehouses. The reason is to deliver the warmer lower temperature colours the lights use a thicker coating layer of yellow or orange phosphorus material on the LED chips to convert the original blue/white light that LED chip emits to a warmer colour. This thicker phosphorus layer also blocks more of the light from getting out. Only until a point..6000k or 8000k will have a very blue hue and begin to become purple the higher you go and will lose output.. We have the LED downlights with adjustable switch and i have them set on 3k in living areas and 4k in bathroom..the 5k setting taints colours in the house and looks odd, i cant see where anyone would use it over the others.. Re: Downlights 75May 11, 2020 4:29 pm I agree with you, however It's a personal and cultural preference. The main reason for 3,4,5K is in the light there are 2 sets of LED chips: 3K and 5K. To deliver desired 4K on the adjustable switch from a minimum quantity of LED chips they mix light from 3K and 5K. This saves both manufacturing and supply chain inventory costs vs. having separate fixed colour down lights. Re: Downlights 76May 11, 2020 4:34 pm 2700K is the old warm yellow 60W traditional edison technology incandescent light colour. 3000K is light delivered by halogen incandescent bulbs which burn a bit whiter and hotter, and slightly more efficiently. LEDs have been designed to mimic these traditional bulb types but using about only 20% of the energy. Coffee shops will run approx. 2000K for ambience. |
