Browse Forums Heating, Cooling & Insulation Re: Hydronic heating panels - what cooling options? 7May 03, 2020 1:07 pm I would go and select in slab hydronic with electrical boiler any time now. It only needs to heat water up to 40 degrees and pretty rarely as the slab conserves the energy due to its thermal mass and insulation. It is just the most efficient way to heat the house up known to date. Full stop. Do not insulate between your floors, so the heated air can rise up and warm up your upper floor bedrooms too. But you would have to invest into good ceiling and under/around slab insulation. Re: Hydronic heating panels - what cooling options? 9May 20, 2020 11:15 pm Radiator panels are great. I have them for 4 years and I'm always comfy with 22 degrees in every room every minute and loving it. I'm using SIME gas boiler as a heating supply. Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 4882 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 4813 Hello - we were hoping to apply laminate click lock panels to our concrete ceiling, but not too sure how to go about attaching the panels to the concrete. Any idea what… 0 1679 |
