Browse Forums General Discussion Re: Seek advice on fixed cost contract, payment term, etc. 2Apr 28, 2020 8:24 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Seek advice on fixed cost contract, payment term, etc. 4Apr 29, 2020 9:01 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Seek advice on fixed cost contract, payment term, etc. 9Apr 29, 2020 11:49 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Seek advice on fixed cost contract, payment term, etc. 10Apr 29, 2020 11:52 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Seek advice on fixed cost contract, payment term, etc. 14Apr 30, 2020 12:30 am Just curious did you get quotes from other builders? Is the builder the one with black and gold in there sign? Re: Seek advice on fixed cost contract, payment term, etc. 15Apr 30, 2020 8:09 am Hi JW001 Thanks for the additional information and that's a large house and the engineering requires upgrading As a structural engineer I would recommend that the slab and footings be upgraded as per AS2870 Residential slabs and footings There's one thing worse that being slugged with high build costs and that's having to X-ray your slab and then finding out the cracks can't be repaired. It's your choice, Please have your proposed build properly scrutinise before you proceed further Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Seek advice on fixed cost contract, payment term, etc. 16Apr 30, 2020 12:54 pm StructuralBIMGuy Hi JW001 Thanks for the additional information and that's a large house and the engineering requires upgrading As a structural engineer I would recommend that the slab and footings be upgraded as per AS2870 Residential slabs and footings There's one thing worse that being slugged with high build costs and that's having to X-ray your slab and then finding out the cracks can't be repaired. It's your choice, Please have your proposed build properly scrutinise before you proceed further Cheers Chris Thanks for your advice. I was told (by other builder) soil class A will be 85mm slab. Is this the AS2870 recommendation? Or I need to upgrade from A85? ( to 100mm slab for example). Also, is the X - ray a compulsory requirement to this size of slab? Could you please share some info. regarding on footing, there are -3C to -7C ( drop footing was allocated $5368 in the builder quotation) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Seek advice on fixed cost contract, payment term, etc. 17Apr 30, 2020 12:57 pm Doozer1905 Just curious did you get quotes from other builders? Is the builder the one with black and gold in there sign? Yes, I got quote from other builder. they are different and list the item in different way Re: Seek advice on fixed cost contract, payment term, etc. 18Apr 30, 2020 1:11 pm Doozer1905 The spot level on the right hand boundary near the 10.5 contour line is 10.6, that's near where the store boundary is at a FFL of 10.957 so approx. 350mm difference, looking at the plan further they have dropped the garage to -4 courses as well so I would assume that has been priced? In regards to the $7894 as a provisional sum that would only cover the following IMO Earthworks Power Run Water Run Sewer Run Maybe a builders Kerb Repair fee as well but I couldn't see anything else for that price. Is a concrete pump included in the house price? We won't use a D10 engineering detail, a 200mm deep footing in our opinion just isn't right, we think it's to thin, I'm not sure if a D10 is a 75mm slab or 85mm, if it's a 75mm slab I would be asking for it to be upgraded to at least 85mm's Here is my cost (preliminary- about 5000 including planning, survey, energy efficiency,etc; electrical included; Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Nothing mention about concrete pump! I will take out the whole boundary walls and fencing section as I will arrange by myself. I will also take out retaining wall ( I will do colorbond fencing with PLINTH, so I can save the retaining cost) Re: Seek advice on fixed cost contract, payment term, etc. 19Apr 30, 2020 1:26 pm Really appreciated you guys giving me so many valuable advice. Thanks all. I got a question whether the zero lot wall there ( store boundary) need any retaining wall or something else? ( only the right side of the store boundary wall) The drawing shows it got -7C footing. floor level - my garage 10.957; the neighbour could be around 10.6, 10.7. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Seek advice on fixed cost contract, payment term, etc. 20Apr 30, 2020 8:04 pm You should be asking these questions of your builders once you receive the engineering You will also need to upgrade your mesh reinforcement to SL62 for what its worth ( Approx $250) Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs There is no reason why building contract reconciliation cannot be done prior to handover, if the builder won't do it get someone to do it for you. Why would you pay for… 3 6690 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 17616 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3597 |
