Browse Forums Building A New House Re: Rawson Balmoral 38 MK1 - Newcastle NSW 121Apr 29, 2020 10:15 pm Week 47: We had ducted air 20kw daikin system installed, was due a fe wmonths ago there had been a supply issue supposedly but the rawson GM got them to do it after he had chased them up! Shower head in ensuite is finally at the right height They installed sliding mesh screens on the alfresco doors. We had the portico and front door painted. Not much to do really, if they were organised we'd be in by now, just things happen at snails pace due to poor planning IMO! Contacted rawson about liquidated damages, apparently its $40 per day that they run over time.. So even if they were 4 weeks over not a huge sum of $ to cover costs of putting your belongings in storage and renting somewhere? Re: Rawson Balmoral 38 MK1 - Newcastle NSW 124May 06, 2020 12:46 am luxbuild Thats disappointing. Have you had the same site supervisor the whole build? We lost one supervisor approx 3-4 months into the build, same supervisor for say past 8 months Re: Rawson Balmoral 38 MK1 - Newcastle NSW 125May 07, 2020 11:59 am We have a walk through possibly booked in for week 50! So hopefully handover by week 52-53! It's certainly been a long time coming!!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Rawson Balmoral 38 MK1 - Newcastle NSW 126May 07, 2020 4:26 pm ourrawsonbalmoral38
Take care interpreting Rawson Homes' 'walk through advice' document. Although its a useful guide, this document is quite deceptive and misleading. It makes some key selective omissions which could deflect their customers' focus from identifying common defects, suiting their own objectives. It is selective in what content they quote from the NSWDFT Guide to Standards and Tolerances, focussing on the preliminary notes in the NSW guide about viewing angles and light for identifying minor blemishes in surfaces and paintwork etc. Focussing on this subjective 'viewing' guide works very well for builders in such inspections, particularly with naive, rushed,1st time buyers, flat paint, and often low surface light from cheap halogen batten lights or 90 degree down lights. Rawson Homes would rather you feel satisfied identifying minor paint blemishes and marking these with blue tape which can be easily touched up later than checking the more fundamental aspects of a quality build. If you want to ensure your Gyprock walls and ceilings are actually straight per Australian Standards and as agreed in your contract (with no waves and bows), not to mention ensuring your bulkheads and niches are properly square, then you will need to check each wall and ceiling based on the Australian standards tolerances. These are clearly detailed for buyers in sections 10.1 and 10.2 on page 47 of the NSW Fair Trading Guide to Standards and Tolerances: https://www.fairtrading.nsw.gov.au/hous ... tolerances Your or your Rawson Homes SS / private Inspector will need to bring; a portable work light, a stepladder, carpenters square, spirit level, 2 metre straight edge, different size window packers, a small ruler and maybe also a laser levelling tool for good measure. If you identify major defects like crooked walls and ceilings etc you can formally dispute PCI has been achieved following the contract procedure for this. Don't accept any BS from Rawson Homes about the 1500mm viewing, angles and lighting etc. It is the measurements vs. the Australian Standards tolerances that matter here - at this stage he will tell you anything to get your signature. Rawson Homes understands this very well because it is very common (but not acceptable) for contractors to attach the Gyprock to crooked frames. Rawson's site supervisors won't check for this during the build. If you check the Gyprock and it is defective vs standars, don't sign anything under these circumstances. Better to identify such defects early rather than after handover when your final payment has been made. With this knowledge then based on your expectations and personal circumstances you can decide whether to accept such defects or not. In the picture below this Gyprock surface is defective. The black plastic wall packer in between the gyprock and the 2m straight edge is 10mm thick. The Australian Standards (and NSWDFT Guide) tolerance states it is defective if there is more than 5mm variation over a 1.8 m straight edge. In this case to rectify my builder removed the Gyprock, straightened the house frame, then installed new Gyprock. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Rawson Balmoral 38 MK1 - Newcastle NSW 128May 08, 2020 9:42 am ourrawsonbalmoral38 My pleasure! Ideally the straightness of walls and ceilings are checked, and rectified if necessary, at earlier building stages well before PCI. The capability, diligence and available time onsite of 3rd party inspectors can vary, therefore I suggest to ensure value that you accompany your inspector on his approx. $600 visit. In addition, you could do the simple yet time consuming inspections yourself. Check the NSWDFT guide which was produced for this purpose. You can ask your Rawson Homes' SS to provide the necessary equipment, and his assistance conducting your inspection; like holding the ladder, taking your photos etc. Re: Rawson Balmoral 38 MK1 - Newcastle NSW 129May 11, 2020 10:24 pm Week 49: We had staining of timber in stairway done, not real happy with the substandard filling and lack thereof of sanding before staining.. Their choice of timber filler is way off also looks too dark... Here is a pic where they've adequately sanded before staining: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Substandard: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The stain looks a lot darker then the natural satin we chose hmm? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Also I noticed that we'd paid for an extra ducted A/C controller to be installed downstairs and its not there... Couldn't see it in any of the logical places where it should be installed? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We also had tiles in our laundry finished off, for some reason they only done 3 rows high should be 5 rows high up to the shelf. Looks a lot better now, really happy with how the laundry looks (forgot to snap a pic, but pic below is how it looked before) Week 50: house cleaners are booked silicon seal of wet areas, all rubbish removed and walk through booked late in week 50. Re: Rawson Balmoral 38 MK1 - Newcastle NSW 130May 11, 2020 11:18 pm That screen might be a different wood which could explain the colour, but obviously the expectation is to match colours and not use the same stain on both. Although if you have chosen the lightest one, Im not sure how they could lighten the screen. Hope you track down your second controller.. they aren't cheap! I remember a while ago there was a thread on here about having a second controller using the Daikin wifi control, but I see in your earlier posts you mention a second controller downstairs. I wonder if they might have done a wifi one? Certainly easier for the installer. Two places that Rawson seem to fail on is stairs and airconditioning. Actually what happened to the outlet that was going to be near the alfresco door? Did you get that sorted to your satisfaction? Re: Rawson Balmoral 38 MK1 - Newcastle NSW 131May 11, 2020 11:30 pm Our second controller is at the bottom of the stairs. Main controller is at the top of the stairs. We initially said no to a second but when the electrician was in there we asked about chucking one in. They had no dramas doing it as for some reason they had already run the wires. Re: Rawson Balmoral 38 MK1 - Newcastle NSW 132May 11, 2020 11:54 pm luxbuild That screen might be a different wood which could explain the colour, but obviously the expectation is to match colours and not use the same stain on both. Although if you have chosen the lightest one, Im not sure how they could lighten the screen. Hope you track down your second controller.. they aren't cheap! I remember a while ago there was a thread on here about having a second controller using the Daikin wifi control, but I see in your earlier posts you mention a second controller downstairs. I wonder if they might have done a wifi one? Certainly easier for the installer. Two places that Rawson seem to fail on is stairs and airconditioning. Actually what happened to the outlet that was going to be near the alfresco door? Did you get that sorted to your satisfaction? I think it may be the light, more light upstairs and the timber looks lighter less light downstairs making it appear darker. Here are pics displaying the differences with the light & the timber appeared to be the same type (pics taken prior to staining) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Yes I recall reading someone had a wifi controller installed also! Our variation clearly stated this controller type: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I guess if they've forgotten to run cable they'd just set you up on a wifi setup... Now I'm thinking about it I did see a wifi daikin box in WIR where modem etc will be located wondered what that was and didn't think anymore of it, that'd be it for sure! Regarding the A/C outlet that was supposed to be in the middle of the dining room which was plonked next to alfresco door, they moved it basically kinda close to that timber screen off stairway in the hallway and boxed in section upstairs here where red cross is: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Rawson Balmoral 38 MK1 - Newcastle NSW 133May 12, 2020 12:17 am Salfield Our second controller is at the bottom of the stairs. Main controller is at the top of the stairs. We initially said no to a second but when the electrician was in there we asked about chucking one in. They had no dramas doing it as for some reason they had already run the wires. Wow you got lucky, i asked about installing a CCTV system supervisor said nah cant allow it. I asked the sparky he was too busy to the prewiring as it was just before xmas missed the boat on that one! I wanted main controller downstairs and slave controller upstairs, I didn't get either! I think I'd prefer a wire din unit over wifi also, so I might just have to dig my heels in and get 2nd wired in unit installed also as that's what's in the variation. At no time was I consulted they'd install a wifi system... Have you had any warranty work started yet mate? I raised this issue in novemeber 2019 the poor job on nail hole filling needs to be rectified, SS agreed and said yeh I'm not happy with that work I'm dissapointed in the painters, but yeah 6 + months later still not fixed... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Have excess mortar drops etc on bricks that haven't been cleaned adequately and im sure the tracks in sliding doors etc wont be fully cleaned that are full of concrete and junk all of this will have to get done after handover i bet. Re: Rawson Balmoral 38 MK1 - Newcastle NSW 134Jun 07, 2020 1:28 pm Great thread, mate. Looks like I'll be the next Rawson on the block. Pretty sure I'm building in the remaining blocks to your right, if I think you are where I think you are. I've been watching the Rawson's along your street over the last two months pretty keenly. Re: Rawson Balmoral 38 MK1 - Newcastle NSW 135Oct 10, 2020 8:07 pm Hi, I was searching the forum and I saw that you got Prime laminate for your floors. We have been suggested this brand and wanted to find out how you are going with the floors that you have? Any issues? Re: Rawson Balmoral 38 MK1 - Newcastle NSW 136Oct 16, 2020 8:59 am jmlight Hi, I was searching the forum and I saw that you got Prime laminate for your floors. We have been suggested this brand and wanted to find out how you are going with the floors that you have? Any issues? We have a few install issues, the co who installed them is being difficult to deal with and we're not getting any resolutions (apparently the boards got wet during transit so we have a few boards in our storeroom which didnt fit right) The product itself though we've been happy with. I wanted solid timber flooring but rawson didnt do it so this was a comprimise. likes: relatively affordable, relatively easy to maintain, if you drop a glass it doesnt smash cons: we have these squeeky spots in the boards where it clicks and crunches as you walk on it (comes and goes dunno if its temperature/humidity dependent?) as mentioned above some boards are protruding due to poor fitment and the installer wont rectify.. Re: Rawson Balmoral 38 MK1 - Newcastle NSW 137Oct 16, 2020 9:01 am mguerre76 Great thread, mate. Looks like I'll be the next Rawson on the block. Pretty sure I'm building in the remaining blocks to your right, if I think you are where I think you are. I've been watching the Rawson's along your street over the last two months pretty keenly. Hi mate jeez sorry for the late reply havent been on homeone for quite some time since our build had been completed and we had handover at the end of may! Our house is definately unique so I dont think you would get us mixed up with anyone else Congrats on your commencement of your build with rawson. That street would be a good little spot tucked away and no traffic going down through there. Let me know if you have any questions or if we can help in any way #rawsongang! Re: Rawson Balmoral 38 MK1 - Newcastle NSW 138Oct 16, 2020 9:29 pm ourrawsonbalmoral38 jmlight Hi, I was searching the forum and I saw that you got Prime laminate for your floors. We have been suggested this brand and wanted to find out how you are going with the floors that you have? Any issues? We have a few install issues, the co who installed them is being difficult to deal with and we're not getting any resolutions (apparently the boards got wet during transit so we have a few boards in our storeroom which didnt fit right) The product itself though we've been happy with. I wanted solid timber flooring but rawson didnt do it so this was a comprimise. likes: relatively affordable, relatively easy to maintain, if you drop a glass it doesnt smash cons: we have these squeeky spots in the boards where it clicks and crunches as you walk on it (comes and goes dunno if its temperature/humidity dependent?) as mentioned above some boards are protruding due to poor fitment and the installer wont rectify.. Thanks for the response. Hopefully you get the issues sorted or at least Rawson helps you to rectify it. Just started the Build process for Chifley 42 with Rawson homes, will keep you all posted with the Build progress. 0 1082 Alternatively, you can sign a contract with pre-defined known amount you pay to the builder for management and warranties and then you just pay the invoices their provide… 2 5254 |
