Browse Forums Windows & Doors Re: Missing brickwork over sliding door 10Apr 28, 2020 1:35 pm There is nothing mentioned or drawn to show an alternative wall type above the door. I would expect that other elevations will refer to bricks. Also check your plans as they should show brick veneer at the door. I think they are making it easy for themselves. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Missing brickwork over sliding door 14Apr 29, 2020 1:32 pm Bhaumik The builder needs to put in a steel lintel above the door and lay bricks above it. Its not a big or difficult job and they can cut bricks as necessary to fit. Again, I had a similar issue with my front door which Metricon fixed after I pointed it out to them. The builder is BSing you about this to avoid the rectification work required due to their errors. Re: Missing brickwork over sliding door 15Apr 29, 2020 4:48 pm Bhaumik So that 45 angled double lines means brickwork? Does it mean I should get brickwork over the sliding door as per plan? yes "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11358 Yes, the builder is required to finish the wall. What else have you missed? 1 3386 DIY, Home Maintenance & Repair Hi all, I’m in a house built 7 yrs ago. One bedroom wall faces East and gets strong morning sun. It’s a gyprock wall with hebel exterior. One section of the wall,… 0 2362 |
