Browse Forums Building A New House Re: Front Door Size 4Nov 13, 2019 7:33 am Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Front Door Size 7Nov 14, 2019 11:09 am https://thomasarcherbuild.blogspot.com/p/blog-page.html - Thomas Archer Homes - Custom Nouveau 41 Re: Front Door Size 8Apr 22, 2020 11:58 pm Scott m dga Not sure if you can go wider based on the floorplan, but if you can I would. 1200mm is a perfect size for a front door. Managed to change to 920 which I'm happy with sample house has that size I think it's the widest can go with that floor plan Which door company is that 920 from. I checked with Hume couldn't find any. My hallway is 1200 but with 2700 ceiling. Not sure which door size to put. 820 is too skinny. Re: Front Door Size 10Apr 23, 2020 2:23 pm You could also consider a double door - 2 x 820. Not that expensive and when you need to move stuff in open both doors and you have tons of room. We've done it last 2 houses and wouldnt go back to single door. Assuming of course it fits. Re: Front Door Size 11Apr 23, 2020 3:07 pm Funnily enough 820 doors are pretty standard and its only been the last 8-10 years that the 1200 door has become popular The pivot doors dont actually give you the full width of the door, you lose some width because of the mechanism, it all depends on the façade, the width of your home generally and if it can fit. Finally it depends on the door manufacturer, some doors do not come 2340 x 920 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3546 Building Standards; Getting It Right! AS2047 Section 6 Page 31 speaks to Construction/Tolerances of Windows and external glazed doors in buildings Check also New South Wales Guide to Standards and Tolerances,… 12 24766 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7493 |
