Browse Forums Outdoor Living 1 Apr 21, 2020 5:10 pm For the under construction house, Alfresco is about 2.2m wide and 5.5m long. Pic attached. There are 3 Brick Peirs on the longer sude blocking the view from Family and also making the Alfresco looks very narrow. What can we do about it? Is it worth tearing these piers down to put Metal pillars? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Alfresco - Brick piers 2May 01, 2020 4:28 pm You could remove the centre pier and replace the beam/lintel with a larger unit that has the specification to span the entire opening. IMO, metal posts would look like a cheap add on/afterthought and not match the intended style. 3 719 How good is Simeon?! Always taking time to help others out! Wish we were building in NSW and could work together. Thanks for all that you do! 7 5182 DIY, Home Maintenance & Repair That’s very helpful information. Will find out more from there. Much appreciated. 11 11816 |
