Browse Forums Building A New House Re: Domaine homes by clerondon 108Apr 17, 2020 5:50 am df21 Kery_deep Phil94 Sorry. We did tiles and carpet. I’d say they would use scotia all the displays with laminate have it. Yeh did see some photos and asked people who built with them on fb. Got the answer before questioning them. Thank you very much & stay safe I am building with Domaine as well and we haven’t reached the flooring stage yet. Is there a way for us to avoid scotia? My cabinets on island in kitchen are black and this will look crap with scotia. Have they told you that we have to ask earlier? Had no clue or else would not gone ahead with the skotia. Apparently this is how they work. They even won’t leave the skirting out if you want to do after handover. Ours is a very tiny house 170 sqm for investment & the Skotia in the small rooms was not what was expecting, that’s the reason was looking around before questioning them. You can check with them & stick to your ground to try and get it your way maybe. I read it’s at extra cost to do flooring first and then add the skirting. Can give it a go. Re: Domaine homes by clerondon 111Apr 28, 2020 7:15 am Hi, We are looking at building Nevada 25 in the Hunter region. Read through this forum and the response for Domaine seems to be pretty positive. Can anyone else who has finished their builds share their experience? We are not too familiar with the entire process as this would be our first home. Where could we cut corners in terms of cost savings? Doing stuff ourself? Is the Rinnai ducted air con they're installing any good? Re: Domaine homes by clerondon 112Apr 28, 2020 7:47 am Jacobbby Hi, We are looking at building Nevada 25 in the Hunter region. Read through this forum and the response for Domaine seems to be pretty positive. Can anyone else who has finished their builds share their experience? We are not too familiar with the entire process as this would be our first home. Where could we cut corners in terms of cost savings? Doing stuff ourself? Is the Rinnai ducted air con they're installing any good? We are just getting the ducting done by them and will install the aircon later by ourselves as the one they are providing was not good enough for us as you can’t run ground floor and first floor at the same time. Re: Domaine homes by clerondon 113Apr 28, 2020 7:51 am df21 We are just getting the ducting done by them and will install the aircon later by ourselves as the one they are providing was not good enough for us as you can’t run ground floor and first floor at the same time. Hi df21, Thanks for your reply We are looking at building a Nevada 25 so first floor wouldn't be an issue for us. I'm assuming this would still include the same 14.7kw system so therefore would be enough for a single storey home? Re: Domaine homes by clerondon 114Apr 28, 2020 8:45 am Jacobbby df21 We are just getting the ducting done by them and will install the aircon later by ourselves as the one they are providing was not good enough for us as you can’t run ground floor and first floor at the same time. Hi df21, Thanks for your reply We are looking at building a Nevada 25 so first floor wouldn't be an issue for us. I'm assuming this would still include the same 14.7kw system so therefore would be enough for a single storey home? Yes it should be okay in that case Re: Domaine homes by clerondon 115Apr 28, 2020 9:20 am df21 Jacobbby df21 We are just getting the ducting done by them and will install the aircon later by ourselves as the one they are providing was not good enough for us as you can’t run ground floor and first floor at the same time. Hi df21, Thanks for your reply We are looking at building a Nevada 25 so first floor wouldn't be an issue for us. I'm assuming this would still include the same 14.7kw system so therefore would be enough for a single storey home? Yes it should be okay in that case Awesome! Thanks for the reply I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 109073 Hi there! Putting the feelers out there for those who have (or almost) built with Arli homes! Interested in your experiences who've built from their stock home designs… 0 26375 Hi, I am wondering if anyone has built with Montgomery in the last few years on the Northern Beaches? I don't see the see them around, as I would love to ask how happy… 0 3452 |
