Browse Forums General Discussion 1 Apr 15, 2020 10:02 am Hello Please help! I’m wanting to fix a shelf that will be taking some weight into a 110 year old limestone wall The wall is plastered but beneath the plaster is quite crumbly. And solid, no cavity in the old days. Any suggestions? We thought using a board along the wall fixing with liquid nails, wall plugs and screws then drill the shelf brackets onto the board? Thanking you for all suggestions Jane Re: Fixing into 100 year old limestone wall 3Apr 16, 2020 7:59 pm Could you maybe cut a series of vertical grooves in the plaster then transfer the weight to the floor via rods/bars or similar. I suppose brackets below the shelf would do at the top. Fixing the bottom might be awkward mind. Replaster when done to hide the trickery. Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10874 DIY, Home Maintenance & Repair All my inside walls are Fibre Cement & House has Steel frames... Tricky when one wants to hang pictures or do Wainscoating Paneling up the hallway. Those little nail… 0 3955 As is per usual for many of the past failed RWH regulations, it is probably traceable to a bureaucrat who's ego overrode the need to seek the appropriate expert… 1 1701 |
