Browse Forums Building A New House 1 Apr 13, 2020 9:22 pm Read my first home build journey by clicking the following link Building with SJD Homes in 2020 - Charleston 310 Customised Re: Insulation Question for Windows, Walls, Ceiling and Roof 3Apr 14, 2020 12:58 am Read my first home build journey by clicking the following link Building with SJD Homes in 2020 - Charleston 310 Customised Re: Insulation Question for Windows, Walls, Ceiling and Roof 4Apr 14, 2020 9:33 am I'm no expert, but I think you've got the order correct. You can't do the anticon, wall wrap or wall insulation easily later. The only thing that can be later is the ceiling insulation upgrade, but it's also the most important, as hot air rises to the ceiling.
So I guess the best of these options is to forego the double glazed door, which I presume is an expensive upgrade. Don't forget good, well insulated window furnishings. Honeycomb (cellular) blinds are the best, but also not cheap. If you go curtains, don't forget to also build pelmets, for increased energy efficiency. The main way to reduce price would be to reduce the house size, this looks pretty big. How big is your family size? If you have one, the guest room could be removed, & the theatre could do double to accommodate the occasional guest. The powder room could be incorporated into the laundry etc. Reducing the house size will not only save you money at the time of the build, you'll save on heating/cooling costs, & on maintenance. Reducing window sizes will save you some money. Many Aussie homes are overglazed, few would be understand. If you're planning on having gas to the home, another way to save money is to ditch the gas & have an all-electric home. It's the way of the future, gas is old thinking. Reverse cycle AC is now cheaper to heat a home than gas. If you can eliminate use of gas - with RCAC for heating/cooling, heat pump or electric element hot water, induction cooking - you'll not only save money during the build by not requiring a gas connection, you'll also save money on you energy bills. The daily service charge for gas adds up to hundreds & hundreds of dollars a year, that's just for the connection, not the usage! Skip the gas & you won't be paying this daily fee. Definitely get solar PV on the roof as quickly as possible. It will pay for itself in 3-5 year (possibly less in Victoria, due to generous rebates). It will be saving you lots of money, especially if you have an all-electric home. Looking at the plan, which way is north? Re: Insulation Question for Windows, Walls, Ceiling and Roof 5Apr 14, 2020 9:41 am looks like a single glaze window has an r-value around 0.2 being such a large window and cost to replace at a later date, i would find the money somewhere https://www.consumer.org.nz/articles/double-glazing Re: Insulation Question for Windows, Walls, Ceiling and Roof 6Apr 14, 2020 8:40 pm ![]() I'm no expert, but I think you've got the order correct. You can't do the anticon, wall wrap or wall insulation easily later. The only thing that can be later is the ceiling insulation upgrade, but it's also the most important, as hot air rises to the ceiling. So I guess the best of these options is to forego the double glazed door, which I presume is an expensive upgrade. Don't forget good, well insulated window furnishings. Honeycomb (cellular) blinds are the best, but also not cheap. If you go curtains, don't forget to also build pelmets, for increased energy efficiency. The main way to reduce price would be to reduce the house size, this looks pretty big. How big is your family size? If you have one, the guest room could be removed, & the theatre could do double to accommodate the occasional guest. The powder room could be incorporated into the laundry etc. Reducing the house size will not only save you money at the time of the build, you'll save on heating/cooling costs, & on maintenance. Reducing window sizes will save you some money. Many Aussie homes are overglazed, few would be understand. If you're planning on having gas to the home, another way to save money is to ditch the gas & have an all-electric home. It's the way of the future, gas is old thinking. Reverse cycle AC is now cheaper to heat a home than gas. If you can eliminate use of gas - with RCAC for heating/cooling, heat pump or electric element hot water, induction cooking - you'll not only save money during the build by not requiring a gas connection, you'll also save money on you energy bills. The daily service charge for gas adds up to hundreds & hundreds of dollars a year, that's just for the connection, not the usage! Skip the gas & you won't be paying this daily fee. Definitely get solar PV on the roof as quickly as possible. It will pay for itself in 3-5 year (possibly less in Victoria, due to generous rebates). It will be saving you lots of money, especially if you have an all-electric home. Looking at the plan, which way is north? Thanks for the valuable information. The North is on the back side of the house but 25-30 degree towards the alfresco corner. Read my first home build journey by clicking the following link Building with SJD Homes in 2020 - Charleston 310 Customised Re: Insulation Question for Windows, Walls, Ceiling and Roof 7Apr 14, 2020 8:57 pm If you do not upgrade door in the laundry, you would have to install insulation into laundry walls as well as seal the internal door. Same applies to WIP door, but there is no internal door there, so this strategy won't work. Your stacker doors will be the major cold bridge which won't be letting much of the passive solar heat during a day as your outdoor living area roof will be blocking high winter sun, unless you make the roof retractable. But even if you sort out passive solar, the heat won't be staying inside for long as during the night it will be easily escaping through your stackers, so in the morning whole area will be damn cold. You seem to have extra huge windows on the western side too (meals and family areas), they will be creating issues with the heat during summer for your unless you find the way to shade them out, even if they are double glazed, heat still will be an issue without proper shading + you would definitely require Low E glazing over there. Also, your laundry and WIP doors seem to be ultra wide without any true purpose, you will be much better off with just partially double glazed door which is not more than 930 cm wide. Re: Insulation Question for Windows, Walls, Ceiling and Roof 8Apr 14, 2020 9:33 pm Other than that: 1) consider basins in your WCs; 2) consider replacing CSDs with hinged doors - they will be too noisy for the bedrooms and causing maintenance issues in the long run. Hinged doors will be cheaper too. 3) double check if CSD between family and bedrooms is unlikely to be used at all and doesn't make much sense to have it there at all (just leave nice opening over there or in the worst case hinged door). 4) 610 slider robes won't be able to hold anything in it. You will lose 100 mm on sliding mechanism, so you will end up with 510 robes which won't be good enough to hold even summer clothes, not talking about winter clothes which generally require at least 600 mm + slider. In fact, you have even less space there as it is 610 mm with the wall, so, in fact, you are closer to 420 mm over there - absolutely useless robes. General recommendation - if you have enough space to open the doors, don't go with sliders. You are also losing some of the horizontal robe space on that gyprock wall on the other side, instead of having a proper built-in robe with all the robe wall there. 5) it won't be very convenient to cook in your kitchen with the sink being in WIP and cooker in the main kitchen. I would rather move sink to an island or at least put it where your fridge is + make WIP opening wider (align it with your WIP external door, it will look nicer this way). The space in the corner to the right of your current sink will perfect for the fridge. You generally keep bin under the sink, too. In general, your kitchen is really tiny and I would rather to extend it all the way along the way to the pantry area and live only small area where you sink is as an actual pantry space. 6) garage doors opening inside eat out valuable space you can use to park your cars. Your garage is certainly not extra long. 7) you would want your bath to fill all the opening space so you don't have to tile over the edges, it is never a good option as the water will be constantly slashing over the edges and then dripping on the floor around. Save some money on tiling, too. Just my 2 cents. Re: Insulation Question for Windows, Walls, Ceiling and Roof 9Apr 15, 2020 12:11 pm ![]() Other than that: 1) consider basins in your WCs; 2) consider replacing CSDs with hinged doors - they will be too noisy for the bedrooms and causing maintenance issues in the long run. Hinged doors will be cheaper too. 3) double check if CSD between family and bedrooms is unlikely to be used at all and doesn't make much sense to have it there at all (just leave nice opening over there or in the worst case hinged door). 4) 610 slider robes won't be able to hold anything in it. You will lose 100 mm on sliding mechanism, so you will end up with 510 robes which won't be good enough to hold even summer clothes, not talking about winter clothes which generally require at least 600 mm + slider. In fact, you have even less space there as it is 610 mm with the wall, so, in fact, you are closer to 420 mm over there - absolutely useless robes. General recommendation - if you have enough space to open the doors, don't go with sliders. You are also losing some of the horizontal robe space on that gyprock wall on the other side, instead of having a proper built-in robe with all the robe wall there. 5) it won't be very convenient to cook in your kitchen with the sink being in WIP and cooker in the main kitchen. I would rather move sink to an island or at least put it where your fridge is + make WIP opening wider (align it with your WIP external door, it will look nicer this way). The space in the corner to the right of your current sink will perfect for the fridge. You generally keep bin under the sink, too. In general, your kitchen is really tiny and I would rather to extend it all the way along the way to the pantry area and live only small area where you sink is as an actual pantry space. 6) garage doors opening inside eat out valuable space you can use to park your cars. Your garage is certainly not extra long. 7) you would want your bath to fill all the opening space so you don't have to tile over the edges, it is never a good option as the water will be constantly slashing over the edges and then dripping on the floor around. Save some money on tiling, too. Just my 2 cents. alexp79 wow, that are amazing suggestions... We already likes some of them and have planned with my spouse to sit and go through all of them for re-consideration. As we are building our first home so these tips are literally Gold for us. Appreciate your help and time. Read my first home build journey by clicking the following link Building with SJD Homes in 2020 - Charleston 310 Customised Re: Insulation Question for Windows, Walls, Ceiling and Roof 10Apr 15, 2020 1:54 pm if this is your first build https://forum.homeone.com.au/viewtopic.php?t=5823 Re: Insulation Question for Windows, Walls, Ceiling and Roof 11Apr 15, 2020 4:17 pm It's nice to have a sink close to the outdoors window to hand back dirty dishes (especially as the dishwasher is there too), but as it's not part of the kitchen, then when entertaining when it's cold outside, then whoever is washing dishes or loading the dishwasher is out of the room where your guests will be (meals or family room). We are planning a small sink in the butler's pantry (as it has no windows to anywhere else), but the main sink and dishwasher are in the island bench, so you can stay with your guests while rinsing and washing dishes! It's also less distance to carry plates to and from the meals area, which is (overall) where you will have the most meals during the year! Victoria's weather can be a bit fickle when it comes to outdoor activity! Re: Insulation Question for Windows, Walls, Ceiling and Roof 12Apr 16, 2020 10:04 am [quote="murtaza.sh":vz7pnahh]Thanks for the valuable information. The North is on the back side of the house but 25-30 degree towards the alfresco corner.[/quote:vz7pnahh] So the back of the home faces NNE, this is a great aspect. But I'm sorry to say it's totally wasted on bedroom 4 & the alfresco area. A north facing backyard is highly sort after, as a living area adjoining it will also be north facing. As the sun is in the northern sky, lower in the sky in winter, northern living areas will receive light & winter sunshine. While they're shaded in summer (by appropriate length eaves), when the sun is higher in the sky. This is called "passive solar design", & is critical for energy efficient house design, comfort, & minimisation of energy bills. This brilliant government website explains it all. https://www.yourhome.gov.au/passive-design So I think it's important that you make changes to your plan, so that some living areas face north. It's great that you bedrooms face ESE, the cooler side of the house. But I'd be looking at moving the home theatre to the western side, sliding the minor bedrooms further forward, moving the alfresco to the SE corner adjacent to bedroom 4, moving the living areas further north. Then the living areas will gain winter sunshine. 1sqm of sunshine can contain up to 1kW of heat. That is a lot! A glazed north facing living area can produce as much heat as your heater. But in their current location the living areas will be shaded by the alfresco for much of the day. Losing valuable sunshine in winter. All homes should incorporate passive design & correct orientation. It's a blight on the building industry that this is not the case. It's the homeowners that suffer, with higher bills, in homes that are darker, colder in winter, hotter in summer. It's great that you're upping the insulation levels. But really you've got to get the basics right first. The basics are getting the orientation right. This is critical in determining a home's comfort, & this is absolutely FREE! Re: Insulation Question for Windows, Walls, Ceiling and Roof 14Apr 22, 2020 7:12 pm ![]() Other than that: 1) consider basins in your WCs; 2) consider replacing CSDs with hinged doors - they will be too noisy for the bedrooms and causing maintenance issues in the long run. Hinged doors will be cheaper too. 3) double check if CSD between family and bedrooms is unlikely to be used at all and doesn't make much sense to have it there at all (just leave nice opening over there or in the worst case hinged door). 4) 610 slider robes won't be able to hold anything in it. You will lose 100 mm on sliding mechanism, so you will end up with 510 robes which won't be good enough to hold even summer clothes, not talking about winter clothes which generally require at least 600 mm + slider. In fact, you have even less space there as it is 610 mm with the wall, so, in fact, you are closer to 420 mm over there - absolutely useless robes. General recommendation - if you have enough space to open the doors, don't go with sliders. You are also losing some of the horizontal robe space on that gyprock wall on the other side, instead of having a proper built-in robe with all the robe wall there. 5) it won't be very convenient to cook in your kitchen with the sink being in WIP and cooker in the main kitchen. I would rather move sink to an island or at least put it where your fridge is + make WIP opening wider (align it with your WIP external door, it will look nicer this way). The space in the corner to the right of your current sink will perfect for the fridge. You generally keep bin under the sink, too. In general, your kitchen is really tiny and I would rather to extend it all the way along the way to the pantry area and live only small area where you sink is as an actual pantry space. 6) garage doors opening inside eat out valuable space you can use to park your cars. Your garage is certainly not extra long. 7) you would want your bath to fill all the opening space so you don't have to tile over the edges, it is never a good option as the water will be constantly slashing over the edges and then dripping on the floor around. Save some money on tiling, too. Just my 2 cents. alexp79 Great suggestions. Thanks once again. Just a question regarding the #6. Can't understand your point there as it is remote control panel lift door which (I think) will slide up and will go backward with the garage ceiling. Something like this Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Or can you please help me understand what you mean? Read my first home build journey by clicking the following link Building with SJD Homes in 2020 - Charleston 310 Customised Re: Insulation Question for Windows, Walls, Ceiling and Roof 15Apr 22, 2020 7:27 pm ![]() ![]() Other than that: 1) consider basins in your WCs; 2) consider replacing CSDs with hinged doors - they will be too noisy for the bedrooms and causing maintenance issues in the long run. Hinged doors will be cheaper too. 3) double check if CSD between family and bedrooms is unlikely to be used at all and doesn't make much sense to have it there at all (just leave nice opening over there or in the worst case hinged door). 4) 610 slider robes won't be able to hold anything in it. You will lose 100 mm on sliding mechanism, so you will end up with 510 robes which won't be good enough to hold even summer clothes, not talking about winter clothes which generally require at least 600 mm + slider. In fact, you have even less space there as it is 610 mm with the wall, so, in fact, you are closer to 420 mm over there - absolutely useless robes. General recommendation - if you have enough space to open the doors, don't go with sliders. You are also losing some of the horizontal robe space on that gyprock wall on the other side, instead of having a proper built-in robe with all the robe wall there. 5) it won't be very convenient to cook in your kitchen with the sink being in WIP and cooker in the main kitchen. I would rather move sink to an island or at least put it where your fridge is + make WIP opening wider (align it with your WIP external door, it will look nicer this way). The space in the corner to the right of your current sink will perfect for the fridge. You generally keep bin under the sink, too. In general, your kitchen is really tiny and I would rather to extend it all the way along the way to the pantry area and live only small area where you sink is as an actual pantry space. 6) garage doors opening inside eat out valuable space you can use to park your cars. Your garage is certainly not extra long. 7) you would want your bath to fill all the opening space so you don't have to tile over the edges, it is never a good option as the water will be constantly slashing over the edges and then dripping on the floor around. Save some money on tiling, too. Just my 2 cents. alexp79 Great suggestions. Thanks once again. Just a question regarding the #6. Can't understand your point there as it is remote control panel lift door which (I think) will slide up and will go backward with the garage ceiling. Something like this Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Or can you please help me understand what you mean? I was talking about internal garage door leading into your house as well as a smaller door leading outside. Re: Insulation Question for Windows, Walls, Ceiling and Roof 16Apr 25, 2020 8:06 pm ![]() ![]() ![]() Other than that: 1) consider basins in your WCs; 2) consider replacing CSDs with hinged doors - they will be too noisy for the bedrooms and causing maintenance issues in the long run. Hinged doors will be cheaper too. 3) double check if CSD between family and bedrooms is unlikely to be used at all and doesn't make much sense to have it there at all (just leave nice opening over there or in the worst case hinged door). 4) 610 slider robes won't be able to hold anything in it. You will lose 100 mm on sliding mechanism, so you will end up with 510 robes which won't be good enough to hold even summer clothes, not talking about winter clothes which generally require at least 600 mm + slider. In fact, you have even less space there as it is 610 mm with the wall, so, in fact, you are closer to 420 mm over there - absolutely useless robes. General recommendation - if you have enough space to open the doors, don't go with sliders. You are also losing some of the horizontal robe space on that gyprock wall on the other side, instead of having a proper built-in robe with all the robe wall there. 5) it won't be very convenient to cook in your kitchen with the sink being in WIP and cooker in the main kitchen. I would rather move sink to an island or at least put it where your fridge is + make WIP opening wider (align it with your WIP external door, it will look nicer this way). The space in the corner to the right of your current sink will perfect for the fridge. You generally keep bin under the sink, too. In general, your kitchen is really tiny and I would rather to extend it all the way along the way to the pantry area and live only small area where you sink is as an actual pantry space. 6) garage doors opening inside eat out valuable space you can use to park your cars. Your garage is certainly not extra long. 7) you would want your bath to fill all the opening space so you don't have to tile over the edges, it is never a good option as the water will be constantly slashing over the edges and then dripping on the floor around. Save some money on tiling, too. Just my 2 cents. alexp79 Great suggestions. Thanks once again. Just a question regarding the #6. Can't understand your point there as it is remote control panel lift door which (I think) will slide up and will go backward with the garage ceiling. Something like this Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Or can you please help me understand what you mean? I was talking about internal garage door leading into your house as well as a smaller door leading outside. Ah, alright. got your points regarding the two internal doors from the garage... Thanks Read my first home build journey by clicking the following link Building with SJD Homes in 2020 - Charleston 310 Customised Re: Insulation Question for Windows, Walls, Ceiling and Roof 17May 14, 2020 1:52 pm ![]() We are building a single story house (drawing attached). We've chosen the following 1. Roof: Colorbond + Bradford Anticon R1.3 2. Ceiling: R3.5 BATTS 3. Wall: Sisalation (Superstrong Breather) + R2.5 BATTS to external walls. 4. Windows: Double Glazed Windows However, the stackers, a sliding door and window in WIP, sliding door in Laundry are still single glazed that we didn't upgrade due to our budget. Our main concern is Winter (cold). 1. Would there be significant difference in temperature in the living and kitchen area in winter, if the stackers, sliding door and a window in WIP will be single glazed? I mean, how much would be the difference if we upgrade these to double glazed? 2. Should we consider upgrading these to double glazed and downgrading anything else (mentioned above) which we might have upgraded unnecessarily or not that important as these double glazed stackers and a door & a window is? Or is there anything else which is more important than the stuff I mentioned? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ External wall Sisalation detail Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Double glaze your stacker door as it is in the living area. I would not worry too much about the WIP as long as you can close the internal door. "ECOECO" Double Glazing in Aluminium & Thermally Broken Aluminium Replacement Window Experts Including Installation (Melb) Tel. 1800 326 326 Re: Insulation Question for Windows, Walls, Ceiling and Roof 18May 14, 2020 2:33 pm ![]() ![]() We are building a single story house (drawing attached). We've chosen the following 1. Roof: Colorbond + Bradford Anticon R1.3 2. Ceiling: R3.5 BATTS 3. Wall: Sisalation (Superstrong Breather) + R2.5 BATTS to external walls. 4. Windows: Double Glazed Windows However, the stackers, a sliding door and window in WIP, sliding door in Laundry are still single glazed that we didn't upgrade due to our budget. Our main concern is Winter (cold). 1. Would there be significant difference in temperature in the living and kitchen area in winter, if the stackers, sliding door and a window in WIP will be single glazed? I mean, how much would be the difference if we upgrade these to double glazed? 2. Should we consider upgrading these to double glazed and downgrading anything else (mentioned above) which we might have upgraded unnecessarily or not that important as these double glazed stackers and a door & a window is? Or is there anything else which is more important than the stuff I mentioned? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ External wall Sisalation detail Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Double glaze your stacker door as it is in the living area. I would not worry too much about the WIP as long as you can close the internal door. WIP don't actually have an internal door. Its a square set opening Read my first home build journey by clicking the following link Building with SJD Homes in 2020 - Charleston 310 Customised Re: Insulation Question for Windows, Walls, Ceiling and Roof 19May 14, 2020 3:54 pm ![]() ![]() ![]() We are building a single story house (drawing attached). We've chosen the following 1. Roof: Colorbond + Bradford Anticon R1.3 2. Ceiling: R3.5 BATTS 3. Wall: Sisalation (Superstrong Breather) + R2.5 BATTS to external walls. 4. Windows: Double Glazed Windows However, the stackers, a sliding door and window in WIP, sliding door in Laundry are still single glazed that we didn't upgrade due to our budget. Our main concern is Winter (cold). 1. Would there be significant difference in temperature in the living and kitchen area in winter, if the stackers, sliding door and a window in WIP will be single glazed? I mean, how much would be the difference if we upgrade these to double glazed? 2. Should we consider upgrading these to double glazed and downgrading anything else (mentioned above) which we might have upgraded unnecessarily or not that important as these double glazed stackers and a door & a window is? Or is there anything else which is more important than the stuff I mentioned? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ External wall Sisalation detail Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Double glaze your stacker door as it is in the living area. I would not worry too much about the WIP as long as you can close the internal door. WIP don't actually have an internal door. Its a square set opening Then DG them all it's dearer later... "ECOECO" Double Glazing in Aluminium & Thermally Broken Aluminium Replacement Window Experts Including Installation (Melb) Tel. 1800 326 326 For Perth, the government's 'Your Home' website recommends a minimum of R4.1 for the roof/ceiling, R2.8 for the walls https://www.yourhome.gov.au/passive-design/insulation 5 2797 As per 1. Rip it all out back to bare timber frames. Install new wiring where/if needed, extra data points, insulation in the external walls and re-clad with plasterboard,… 1 1130 I think 4 to 6 there is still a decent amount of gain but beyond that there is no need. Most high performing non-passivehaus (still reasonably affordable) houses I've seen… 5 1358 |
