Browse Forums Building A New House Re: Brick work Mortar cracks 2Apr 07, 2020 7:51 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Brick work Mortar cracks 4Apr 08, 2020 7:53 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Brick work Mortar cracks 6Apr 08, 2020 10:34 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Brick work Mortar cracks 7Apr 09, 2020 11:46 am It would be a good idea to Reference the crack and photos here Checking Cracks above Lintels Using Bosch Laser Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Brick work Mortar cracks 8Apr 12, 2020 2:16 pm franknewhome Update: When builder replace those windows due to wrong size, they cut the original flash and the weep holes just become not functional. There is a big gap between the top course of the brick and the window frame which make the water really easy to get in. The crack looks really wet and all along the line with original weep holes. Any thought how build would fix it? I have talked to them but they did not come and have a look yet. It seems not easy to fix the flash problem, can that be flashed externally ? Thanks Chris, There r 2 210 windows connected, that window has been replaced during construction as the size was slight bigger or something like that. Do you need to get a structural guy to have a look? Since it is still within builder's warranty. Tanks again Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Brick work Mortar cracks 9Apr 13, 2020 9:14 am Unfortunately, the bricks will need to be removed to correctly install the cavity flashing. Also the window company should place additional aluminium trim to better close the gap on the outside BTW moisture doesn't cause bricks to crack (unless it freezes and expands within the brick?) It's more likely tensile stresses, do you need an engineer not unless the cracks are getting worse over time. Monitor the crack patterns and put the builder on notice if the problem persists outside of the structural warranty period. Do you have photos of the wall and roof framing stages at the large window location? Thanks for the information as it also helps others Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Brick work Mortar cracks 10Apr 13, 2020 10:22 am StructuralBIMGuy Unfortunately, the bricks will need to be removed to correctly install the cavity flashing. Also the window company should place additional aluminium trim to better close the gap on the outside BTW moisture doesn't cause bricks to crack (unless it freezes and expands within the brick?) It's more likely tensile stresses, do you need an engineer not unless the cracks are getting worse over time. Monitor the crack patterns and put the builder on notice if the problem persists outside of the structural warranty period. Do you have photos of the wall and roof framing stages at the large window location? Thanks for the information as it also helps others Cheers Chris Thanks chris, that is really helpful information. I was hoping builder can just do some magic without open the brick. But since it is only top course and access is not an issue, it would be half a day job for a decent brick layer? I've attached a couple of more photos, it does look like the brick/mortar shrink and getting loose along the marked line. The evidence is the weep holes plastic has a gap on 3 dimensions, different colour with the mortar and the loose line along the joint between brick and mortars. Also, the frame as a thin timber attached, rather than steel along the line not sure if that is a problem structurally. I tend to believe it is ok? For those who have their window replaced after brick work, this is something to watch out and really easy to get missed!~ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Brick work Mortar cracks 11Apr 13, 2020 10:53 am Ho franknewhome The architectural drawings shows a steel column with studs either side mid window span The photo shows 2 boxed studs can't tell if there is a Steel column encased within? The crack patterns along the horizontal brick line is indicative of the column deflecting outwards If the bottom window sill plate timber stiffener ( Attached within the cavity) rests on the brickwork it might cause it to crack in that location? As you said the bricks will need to be removed and this issue investigated You should also have Engineering floor, Beam and column plan and details,check the floor level/deflection above the window? Checking Suspended Floor Deflections With Bosch Laser Tool OT if you are in a BAL Fire rated area those gaps are too wide? Thanks for the photos Kind Regards Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Brick work Mortar cracks 12Apr 13, 2020 11:54 am StructuralBIMGuy Ho franknewhome The architectural drawings shows a steel column with studs either side mid window span The photo shows 2 boxed studs can't tell if there is a Steel column encased within? The crack patterns along the horizontal brick line is indicative of the column deflecting outwards If the bottom window sill plate timber stiffener ( Attached within the cavity) rests on the brickwork it might cause it to crack in that location? As you said the bricks will need to be removed and this issue investigated You should also have Engineering floor, Beam and column plan and details,check the floor level/deflection above the window? Checking Suspended Floor Deflections With Bosch Laser Tool OT if you are in a BAL Fire rated area those gaps are too wide? Thanks for the photos Kind Regards Chris Thanks Chris, I will double check once the builder open it. By the look of it, that two posts looks slightly different with the normal frame it might be the steel boxed studs ? It would be easy to tell once they open the brick up though. The window is not resting on the brickwork for sure as I can see the gap from the opening and it is below the timber line. The level would be a clearer indication if that is the case, I will see if I can ask the builder the take the levels. I will wait for the builder to have its inspection and monitor the crack at the same time. From my past exp with them it will take months to get it fixed. I think it is a great example of small things can develop overtime and The fix could be a 5 mins attention during construction, sad that my inspector did not pick this up during all stages. Re: Brick work Mortar cracks 13Apr 13, 2020 12:22 pm franknewhome I think it is a great example of small things can develop overtime and The fix could be a 5 mins attention during construction, sad that my inspector did not pick this up during all stages. Lucky you had the correct photos..once covered up often ignored and forgotten As for engineering documentation ideally you also require 1. Footing & Slab Plan & details 2. Brick Lintel, beam and column Plans and details 3. Wall Framing Plans and details 4. Floor Plan joists, Beams, Columns 5.Roof Truss engineering Plan & Details 6. Wind loading connection Details for 3,4 & 5 above If you are missing structural detail items what does the building inspector check read their disclaimer. OT, Builders don't like paying for the full engineering services..so it's not always offered during site inspections.. IMO, legislation should make it mandatory. Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Brick work Mortar cracks 14Apr 13, 2020 12:57 pm StructuralBIMGuy franknewhome I think it is a great example of small things can develop overtime and The fix could be a 5 mins attention during construction, sad that my inspector did not pick this up during all stages. Lucky you had the correct photos..once covered up often ignored and forgotten As for engineering documentation ideally you also require 1. Footing & Slab Plan & details 2. Brick Lintel, beam and column Plans and details 3. Wall Framing Plans and details 4. Floor Plan joists, Beams, Columns 5.Roof Truss engineering Plan & Details 6. Wind loading connection Details for 3,4 & 5 above If you are missing structural detail items what does the building inspector check read their disclaimer. OT, Builders don't like paying for the full engineering services..so it's not always offered during site inspections.. IMO, legislation should make it mandatory. Cheers Chris The building industry in this country sometimes is just a joke with black citizen tradies and builders only cares about money when they should pay attention to these things, our one is decent quality compared to most of the build I've seen but still lots of little hidden problems like this. Initially I was a bit worried about slab heave as that side has a bit of water problem during construction. Luckily our slab has concrete piers surrounded the whole slab and was poured together. It would be a lot worse like other heave thread if not. I'll update this thread after a few month just to help people with similar problems. Re: Brick work Mortar cracks 15Apr 13, 2020 1:00 pm StructuralBIMGuy Lucky you had the correct photos..once covered up often ignored and forgotten Chris Taking photos of everything is very, very wise. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1109 Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 1958 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11234 |
