Browse Forums General Discussion Re: Mortar Defects 4Mar 25, 2020 10:31 pm Does your contract have a certified Performance Solution that allows for a weaker mortar mix? Such Performance Solutions have become common, first thing to do is check your contract. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Mortar Defects 5Mar 26, 2020 6:50 am SaveH2O Does your contract have a certified Performance Solution that allows for a weaker mortar mix? Such Performance Solutions have become common, first thing to do is check your contract. Hi SaveH20 No nothing about Performance Solution...so it looks like weak mortar? Many thanks. Re: Mortar Defects 6Mar 26, 2020 7:25 am Have you contacted the builder? It is best to be prepared. You can get mortar lab tested and doing a forum search using keywords like mortar, lab, test etc should raise a few threads that discuss these issues and costs etc. An initial search using only those three keywords suggested bought up the following threads: search.php?keywords=mortar+lab+test Maybe also measure the perpends, they had to be 10mm +/- 3mm the last I checked but that might have changed. Others can advise. Good luck. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Mortar Defects 7Jul 12, 2020 3:57 pm SaveH2O Have you contacted the builder? It is best to be prepared. You can get mortar lab tested and doing a forum search using keywords like mortar, lab, test etc should raise a few threads that discuss these issues and costs etc. An initial search using only those three keywords suggested bought up the following threads: search.php?keywords=mortar+lab+test Maybe also measure the perpends, they had to be 10mm +/- 3mm the last I checked but that might have changed. Others can advise. Good luck. Thanks! Sorry for the delay just found your message. Still looking into it... Re: Mortar Defects 8Aug 09, 2020 1:30 am hello OP, what did you end up doing finally? Lodged a complaint case with Builder? Re: Mortar Defects 9Mar 02, 2022 8:36 pm It could be the acid used to clean the brick has sat at the base. Put a bead of silicon around base to reduce further erosion. HTH Jessie2019 Hey guys Does anyone know what the issue might be with our brick mortar? It’s only about 9 months old. It appears to be washing away at the base of our Brick pillars and house in some areas. It’s crumbles easily too. Many thanks! [img]https://forum.homeone.com.au/u/93938_1585022541.jpeg[/im Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ *All in my opinion only Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6903 1 9474 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8219 |
