Browse Forums Building A New House Re: Double glaze windows with Low e glass 2Mar 01, 2020 9:29 pm We have lightbridge glass, haven’t noticed any blurring. Re: Double glaze windows with Low e glass 4Mar 02, 2020 3:48 pm We have Low e glass (manufactured by Viridian) on our double set of sliding doors. It is a clear glass but I think there is the slightest grey tinge to it when compared to an adjacent window. Re: Double glaze windows with Low e glass 5Mar 02, 2020 8:11 pm Bebbsy We have Low e glass (manufactured by Viridian) on our double set of sliding doors. It is a clear glass but I think there is the slightest grey tinge to it when compared to an adjacent window. Thanks Bebbsy. Does it effect the outside view when you are looking out from inside the house? As I heard it gives milky look on a glass. Re: Double glaze windows with Low e glass 6Mar 02, 2020 9:07 pm Den45 Bebbsy We have Low e glass (manufactured by Viridian) on our double set of sliding doors. It is a clear glass but I think there is the slightest grey tinge to it when compared to an adjacent window. Thanks Bebbsy. Does it effect the outside view when you are looking out from inside the house? As I heard it gives milky look on a glass. I wouldn’t say milky, perhaps a slight haze is a better description, it’s not crystal clear compared to ordinary glass. Having said that, if you didn’t know it had a different type of glass, I don’t think anyone would even realise the difference. Re: Double glaze windows with Low e glass 7Mar 03, 2020 11:32 am Bebbsy Den45 Bebbsy We have Low e glass (manufactured by Viridian) on our double set of sliding doors. It is a clear glass but I think there is the slightest grey tinge to it when compared to an adjacent window. Thanks Bebbsy. Does it effect the outside view when you are looking out from inside the house? As I heard it gives milky look on a glass. I wouldn’t say milky, perhaps a slight haze is a better description, it’s not crystal clear compared to ordinary glass. Having said that, if you didn’t know it had a different type of glass, I don’t think anyone would even realise the difference. Thanks for your response. Do you think it’s worth having Low e? Re: Double glaze windows with Low e glass 8Mar 03, 2020 3:12 pm We’ve only been in our house for 3 weeks and had no really hot weather in that time so difficult to tell. But as we have fantastic rural views out of these windows and are not planning any window coverings it was a requirement for us to install low e glass in order to meet the 6* energy rating required here in SA. Re: Double glaze windows with Low e glass 9Mar 03, 2020 9:11 pm Bebbsy We’ve only been in our house for 3 weeks and had no really hot weather in that time so difficult to tell. But as we have fantastic rural views out of these windows and are not planning any window coverings it was a requirement for us to install low e glass in order to meet the 6* energy rating required here in SA. Thanks. Good luck with your new home and hope you are enjoying it. Re: Double glaze windows with Low e glass 10Mar 10, 2020 7:50 pm Which direction does the glazing face? What type of low-e coating exactly? To keep the heat from the sun out, or keep your winter heating in? Low SHCG, to keep heat from the direct sun out, or high SHGC, to let it in? Different glazing solutions should be used for different orientations. Re: Double glaze windows with Low e glass 11Mar 11, 2020 10:00 pm ddarroch Which direction does the glazing face? What type of low-e coating exactly? To keep the heat from the sun out, or keep your winter heating in? Low SHCG, to keep heat from the direct sun out, or high SHGC, to let it in? Different glazing solutions should be used for different orientations. It is required as per energy report and we do have some west facing windows to some bedrooms as well. I don't know them all, the first 2 top of your list are best known. Rylock is a good company, Stegbar is for sale. 4 16191 4 6193 If you can calculate the reasonable charged head from let's say 100mm below the gutter to the top of where the vertical riser's horizontal discharge pipe will be, that… 11 17525 |
