Browse Forums General Discussion Re: Building with Eden Brae- Rain coming inside the house 2Feb 25, 2020 7:07 pm Builder is correct, this is on your insurer because of the storm activity, not the builder. The only time it would be on the builder is if the house has not been built to the relevant standards (too many to list that could be relevant) Re: Building with Eden Brae- Rain coming inside the house 3Feb 26, 2020 6:27 am External doors should not let water in. Perhaps the door has a slight warp or some other problem, I don't think you should absolve the builder of responsibility too easily. Re: Building with Eden Brae- Rain coming inside the house 4Feb 26, 2020 7:01 am luxbuild I Agree, aria28 send an email and registered letter to Eden Brae detailing the situation and asking them to investigate the cause and confirm in writing how and when they will fix it. Give them a reasonable time frame to act. Don’t accept their ‘weather’ fob off. The builder is responsible for building to standards and the quality of the products installed, like your door. Eden Brae’s behaviour is unacceptable. It’s a common tactic to blame the weather to avoid responsibility for defects and the rectification costs. Its critical you now keep all communications about this issue in writing. Re: Building with Eden Brae- Rain coming inside the house 5Jul 08, 2020 8:03 pm luxbuild External doors should not let water in. Perhaps the door has a slight warp or some other problem, I don't think you should absolve the builder of responsibility too easily. Thanks for your advice. Sorry haven’t had the time to log in again. Re: Building with Eden Brae- Rain coming inside the house 6Jul 10, 2020 10:36 pm If builder refuses to contact you You could have your insurer come and look. If they identify build faults they will list them for you and refuse to fix carpets until the build issue is fixed. You can use the evidence with the builder. If you can then decide if you will proceed with claim after that point then you have not paid any excess and have the information you need to claim. You could contact consumer affairs re: your rights Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38442 I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 22211 The bottom of the downpipe has been taped (see the black tape) to seal the necessary gap between the downpipe and the adaptor that would normally prevent the downpipe… 3 9196 |
