Browse Forums Building A New House Re: Design suggestions 15Feb 16, 2020 7:18 pm Sorry i understand you want a door on your pantry, i was just saying we had a pantry door on our last house, it opened 180 degrees, you push it inwards to get inside and push it outwards to get out. The hinge was floor and ceiling mounted (like a pivot system), it worked well, i think it would be much better than your current plan which has a door swinging out, i cant imagine Having the door opening into your work space. Re: Design suggestions 16Feb 16, 2020 7:29 pm gogo65 Sorry i understand you want a door on your pantry, i was just saying we had a pantry door on our last house, it opened 180 degrees, you push it inwards to get inside and push it outwards to get out. The hinge was floor and ceiling mounted (like a pivot system), it worked well, i think it would be much better than your current plan which has a door swinging out, i cant imagine Having the door opening into your work space. All good . I guess having a door to the pantry is in general painful but I guess it’s a necessary evil. How did your hinge work ? And how much did that cost ? Sounds like an interesting concept . I might look into it. Re: Design suggestions 17Feb 16, 2020 8:26 pm As Gogo65 I think already said, an outward opening hinged door like that will either be a proper 180 deg hinge (& IMO they look a bit stupid) or a standard hinge that won't properly open all the way out to the wall. Yes it is a silly design (sorry to be blunt) and you will regret I think. You should be able to get a CSD into that wall, and I would upgrade to a 'flush-to-Jamb' type so you don't lose the ~60mm on a standard cavity slider. I would also consider deleting the 2nd sink etc in the WIP and instead use some of that space for a fridge/freezer cavity. Getting these bulky items out of your main kitchen area (but still close and handy) I think is a good move. --------------------------------------------------------------------- Check our Homeone build blog here Re: Design suggestions 18Feb 17, 2020 1:22 pm Sbanu, the hinge was a pivot hinge by hafaele, i think it cost close to $1000, but that was back in 2012. It looked beautiful, completely hidden, flush mounted in the floor, and flush mounted into the ceiling, like I said no handle on the door... Ill try and find a photo.... Re: Design suggestions 20Feb 17, 2020 1:37 pm That’s beautiful ! Love your kitchen and tile selection . Looks like a nice open plan home ! ideal house depends on the site and location as much as internal floor plan....what is the distance from the house to all four boundaries, where is north, describe your… 3 15166 Hi, Looking to add an ensuite to one of the bedrooms and make it a Master BR. Please see the attached current floorplan. Need suggestions on what's the best way to do… 0 7340 Suggestions please for acrylic rendering Color to match austral brick urban one pepper. Pic for reference. Thanks 0 5069 |
