Browse Forums General Discussion Re: Old house with cold double brick walls 7Feb 17, 2020 8:26 am Stewie D Do you also have the internal vents high up close to the cornice in external walls ? Stewie Not any more... I blocked them up on the inside years ago as all the heat was escaping there in winter. Re: Old house with cold double brick walls 8Feb 17, 2020 9:18 am Good idea. Apart from the walls there is not much else you can do seeing as you have the ceiling and floor insulation taken care of. What R rating are they both and did you install them or get someone else to do it? The reason I ask is that I've seen a few jobs in the past where companies have been employed to do it and the end result left a lot to be desired - gaps in insulation between joists, not taken all the way out to the top plate etc. A 5% gap results in 50% less effective insulation. Stewie Re: Old house with cold double brick walls 9Feb 17, 2020 2:17 pm Interesting.... I got both floor and ceiling insulation professionally done but I can see with the thermal camera that there are gaps here and there in the ceiling. The cornices also seem to be an area that lose heat (or lets it in in summer) Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9971 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12666 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2609 |
