Browse Forums Heating, Cooling & Insulation 1 Feb 10, 2020 5:15 pm We are thinking to increase the ceiling height from 2590mm to 2740mm (150mm increase) but wondering how much it will affect the GAS ducted heating efficiency and ongoing cost (if we talk about 1 year in Melbourne). Would there be a major difference in bills in winter due to the above 150mm increase in ceiling height? Read my first home build journey by clicking the following link Building with SJD Homes in 2020 - Charleston 310 Customised Re: Does ceiling height effects heating efficiency &ongoing 2Feb 10, 2020 5:59 pm murtaza.sh We are thinking to increase the ceiling height from 2590mm to 2740mm (150mm increase) but wondering how much it will affect the GAS ducted heating efficiency and ongoing cost (if we talk about 1 year in Melbourne). Would there be a major difference in bills in winter due to the above 150mm increase in ceiling height? It’s a calculation you can do, something like this. Once you know the cost per cubic meter, you can work out how many extra cubic meters you are adding by raising the ceiling...but in short, 15m3 per 100m2 of ceiling space. Then you can multiple by the cost of your energy source (probably in kilojoules). Re: Does ceiling height effects heating efficiency &ongoing 3Feb 25, 2020 7:37 am Are you sure you want to install gas ducted heating? Reverse cycle AC is now the cheapest way to heat a home, & gas is only going to get more expensive. Not to mention how bad it is for the environment.
Plenty of people ditching gas altogether. If I was building a new home I wouldn't be installing gas at all, I'd have an all-electric home, the way of the future. Reverse cycle AC to heat/cool the home, heat pump to heat the water, induction cooktop in the kitchen. Solar PV on the roof. Check out the My Efficient Electric Home (MEEH) Facebook group. go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110572 Approvals are covered in the cost we are paying to the pool company. The only thing stated in our home build contract for the additional cost is engineering support. … 3 7120 ok thanks - yes was wondering if that should have been listed as Option Three! 2 7743 |
