After 30years in the building industry I can promise you that you will never make that look acceptable even if you have solid experience.
That's the reason everyone has said that it needs to be replaced.
Good luck!
Browse Forums DIY, Home Maintenance & Repair Re: Repairing a broken soap holder 21Jan 26, 2020 9:32 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Repairing a broken soap holder 22Jan 26, 2020 9:56 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Repairing a broken soap holder 23Jan 26, 2020 10:03 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Repairing a broken soap holder 28Jan 27, 2020 9:04 pm arcadelt It’s not going to make it look better than what you have already done. When you break a ceramic item, there are always small pieces that go missing. Coupled with the facts that any adhesive has to take up some space to bond the surfaces, and that you can rarely get the two surfaces to line up perfectly, there will still be gaps that are the colour of whatever adhesive you use. That different adhesive is not going to magically be the same colour as the soap dish, so you will still see the cracks. Bunnings doesn't have the Porcelain Fix, however, I was thinking of using some white wet area silicone like this one: https://www.bunnings.com.au/selleys-300g-white-wet-area-silicone_p1230981 At least it would whiten the cracks a little bit and prevent moisture to go inside the soap holder through the bigger crack. At least it will be functional, ugly, but functional. What do you reckon? Re: Repairing a broken soap holder 30Jan 28, 2020 10:29 am arcadelt Kwizak What do you reckon? Absolutely not. Silicon is entirely wrong for what you are trying to do. How so? Does silicon suppose to prevent moisture to enter cracks? I have used silicon before. Why not use it in this case? Re: Repairing a broken soap holder 32Jan 28, 2020 12:05 pm arcadelt Kwizak How so? Does silicon suppose to prevent moisture to enter cracks? I have used silicon before. Why not use it in this case? Never mind. Do as you please. I'm cleaning up the excess of cured epoxy, then I'll leave it at that. Thanks for your time. Re: Repairing a broken soap holder 34Jan 28, 2020 6:46 pm Thanks for the joke. Accidents happen. We are adults. I'll make sure the outcome of this situation benefits the owner. I wanted to fix the issue myself, but yes, the result is not great. Re: Repairing a broken soap holder 37Jan 30, 2020 11:22 am Kwizak Brett0004 I am interested to know how you broke it, or shouldn't I ask. Hi, I invite you to read the first post of this discussion. Fair Point. I initially was reading all the replies. Touche !! Please suggest a solid quality swivel bar towel holder in bathrooms & bedrooms from… 0 1349 I have an investment property and tenants moved out recently. However the Property manager noticed one of the floor tiles is broken and the kitchen Island countertop is… 0 419 |
