Browse Forums Building A New House Re: Void and/or increased ceiling heights 30Jan 14, 2020 12:38 pm We have a void above the entry in our build. It's still at frame stage at the moment so a little hard to picture how successful or otherwise it will be. Canberra knockdown rebuild https://the35thweek.blogspot.com Re: Void and/or increased ceiling heights 31Jan 21, 2020 8:08 pm Ok, I tried to draw it in and it's not working, so I have to explain it. I'd put one in the entry (with a gorgeous light fitting for impact) Then your stairwell also acts as a void. If you must have another one (and bear in mind noise travels up a void) Put it in a long rectangle in the family room and up into the activity room. You could put a feature fireplace in the family room, continue the stone/tiles etc all the way up to 2nd floor ceiling. The heat will rise and assist with warming the room. My 2 cents worth https://thomasarcherbuild.blogspot.com/p/blog-page.html - Thomas Archer Homes - Custom Nouveau 41 Tradie may sit at home but will need to get house plastered as well or will you sit it out? 6 9938 Building Standards; Getting It Right! We bought a house in 2015 advertised as a 7/2/2, 4br up, 3br down (7br), and to date, it’s a great house. However, we’ve just had it valued and it’s come in as a… 0 11965 Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2503 |
