Browse Forums Building A New House Re: Hallmark Retreat 348 2Jan 09, 2020 6:02 pm Follow our build -Â https://forum.homeone.com.au/viewtopic.php?f=31&t=97258&p=1860467#p1860467 Re: Hallmark Retreat 348 4Jan 13, 2020 11:41 am Follow our build -Â https://forum.homeone.com.au/viewtopic.php?f=31&t=97258&p=1860467#p1860467 Re: Hallmark Retreat 348 5Jan 13, 2020 7:10 pm Thanks Hayley, We have organized to see the Display home at Upper Caboolture this staurday. Can't find your plans on the post. If your able to put up again that would be great. Quick question do you know if they have an option to do steel frame. Thanks Re: Hallmark Retreat 348 7Jan 15, 2020 8:27 pm MICHAELJ Thanks Hayley, We have organized to see the Display home at Upper Caboolture this staurday. Can't find your plans on the post. If your able to put up again that would be great. Quick question do you know if they have an option to do steel frame. Thanks Im not sure but Tim will definitely let you know when you see him and i will get our final plans up shortly Just doing an update of where progress is at Follow our build -Â https://forum.homeone.com.au/viewtopic.php?f=31&t=97258&p=1860467#p1860467 Re: Hallmark Retreat 348 8Jan 15, 2020 8:28 pm kateishaloersch Hey Hayley, sent you a private message on here I will check it out Follow our build -Â https://forum.homeone.com.au/viewtopic.php?f=31&t=97258&p=1860467#p1860467 Re: Hallmark Retreat 348 9Jan 15, 2020 10:56 pm Follow our build -Â https://forum.homeone.com.au/viewtopic.php?f=31&t=97258&p=1860467#p1860467 Re: Hallmark Retreat 348 10Jan 16, 2020 8:11 am Thanks Hayley, Looks like you only did some minor changes around kitchen/Laundry area. Did you cut back on island bench & how big is it now compared to before, we are wanting the sink under the window as well so we can look out at our 3 acres when washing up. Re: Hallmark Retreat 348 11Jan 17, 2020 4:44 pm MICHAELJ Thanks Hayley, Looks like you only did some minor changes around kitchen/Laundry area. Did you cut back on island bench & how big is it now compared to before, we are wanting the sink under the window as well so we can look out at our 3 acres when washing up. Yeah and closed in the media and study as they are open plan. Troy refused to have the sink in the island and we had the same thing that we wanted to be able to see outside. I would have to check the original vs our plans now for changes in size but I'll do that when i can for you Follow our build -Â https://forum.homeone.com.au/viewtopic.php?f=31&t=97258&p=1860467#p1860467 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13890 |
