Browse Forums Kitchen Corner 1 Dec 31, 2019 3:50 pm I was tiling my kitchen space in subway pattern only to discover that the wall is not perfectly square. So half the space at top is to small for the tile by about 2-3mm. I have tried using a hand grinder but the tile is very solid and strong. All i get is sparks. Even if I leave out the 1.5mm space for grouting (which i dont want to) I still cant get it in. Anyone with experience know what to do? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Suggestion on Wall Tiles Not fitting 2Dec 31, 2019 4:10 pm Sounds like the grinding blade issue to be honest, you should be using a blade similiar to the attached and remember they are directional when you put it on the grinder. Other than that it looks sexy!! Well done!! Myles Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. Re: Suggestion on Wall Tiles Not fitting 3Dec 31, 2019 4:12 pm Critical that it is a continuous blade, like this. https://www.bunnings.com.au/full-boar-2 ... lsrc=aw.ds Myles Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. Re: Suggestion on Wall Tiles Not fitting 4Dec 31, 2019 4:32 pm Thanks Myles. I have no experience with grinder so i appreciate the pic. Its a bunnings link which is great. I have a bunnings nearby. Will give it a shot. Steve Re: Suggestion on Wall Tiles Not fitting 5Dec 31, 2019 6:59 pm Steve Zero Thanks Myles. I have no experience with grinder so i appreciate the pic. Its a bunnings link which is great. I have a bunnings nearby. Will give it a shot. Steve For someone with no experience it looks fantastic. Let me know if you need some pointers for grouting it. Please make sure you wear ear and eye protection will grinding tiles, they make an absolute mess of you when things go wrong. Also be sure to send those finished pictures and show off the great work Myles Clark Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. I am currently doing a bathroom renovation and want to put in a window that is narrow than the current one in a brick opening. Can I fit the window on the bottom noggin… 0 830 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 12162 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9570 |
