Browse Forums Heating, Cooling & Insulation Re: New Build - Ducted Refrigerated OR R/c Multi Splits OR R 15Dec 29, 2019 11:43 am Hey lucky88x Brivis provides gas heating mainly and the option you mentioned is an addon for cooling using the same ducted system. The quote I gave was for all electric air-con. In general there are a few options 1. As you have, gas heating and either evaporated cooling (low power usage) or refridgerated cooling as addon. 2. Fully electric air conditioning as information I provided. Some give zone control and multiple outlet throughout the house with either round vents or square with adjustable angles. 3. Multi head aircon system which means each room will have an indoor unit for both heating and cooling, same as normal aircon, and only one big outdoor unit. This will give advantages as to control temperature for each room but you will need to consider hallway and other areas in the house as well. Hope it helps. Re: New Build - Ducted Refrigerated OR R/c Multi Splits OR R 16Jan 01, 2020 7:45 am ddarroch I'd ditch gas totally. Don't even connect it to your house in this day & age. You'll save money (no daily supply charges for the gas), & help save the environment. Go an all electric house. As suggested, 6.6kW of solar PV on the roof (make sure your roof is designed well, to accommodate north, or east/west facing panels). RC AC to heat/cool the home. Plus fans to cool (way less energy usage). Evaporative cooling is cheap to run, but only good in very dry climates, not Melbourne. Heat pump or electric element domestic hot water (powered by solar PV). Induction cooktop. Gas bottle for the BBQ. As for your initial questions. Splits are more efficient than ducted (due to energy losses in the ducts). So I'd be looking at splits, maybe multi heads, & maybe a single head or two, whatever fits. I believe single head are usually more efficient? Hey ddarroch - am also looking to do a new build in Donnybrook (VIC 3064) and have been recommended "Solaray" to do a roof solar panel install (with EnPhase brand microinverters) and a Tesla PowerWall2. Any other installers you would recommend that would service the Kalkallo / Donnybrook area? Re: New Build - Ducted Refrigerated OR R/c Multi Splits OR R 17Jan 01, 2020 9:28 am TeslaCyberTruck ddarroch I'd ditch gas totally. Don't even connect it to your house in this day & age. You'll save money (no daily supply charges for the gas), & help save the environment. Go an all electric house. As suggested, 6.6kW of solar PV on the roof (make sure your roof is designed well, to accommodate north, or east/west facing panels). RC AC to heat/cool the home. Plus fans to cool (way less energy usage). Evaporative cooling is cheap to run, but only good in very dry climates, not Melbourne. Heat pump or electric element domestic hot water (powered by solar PV). Induction cooktop. Gas bottle for the BBQ. As for your initial questions. Splits are more efficient than ducted (due to energy losses in the ducts). So I'd be looking at splits, maybe multi heads, & maybe a single head or two, whatever fits. I believe single head are usually more efficient? Hey ddarroch - am also looking to do a new build in Donnybrook (VIC 3064) and have been recommended "Solaray" to do a roof solar panel install (with EnPhase brand microinverters) and a Tesla PowerWall2. Any other installers you would recommend that would service the Kalkallo / Donnybrook area? Hey Tesla, How r u getting the solar installation done with the initial build?? Cheers, Re: New Build - Ducted Refrigerated OR R/c Multi Splits OR R 18Jan 01, 2020 9:40 am Lucky88X TeslaCyberTruck ddarroch I'd ditch gas totally. Don't even connect it to your house in this day & age. You'll save money (no daily supply charges for the gas), & help save the environment. Go an all electric house. As suggested, 6.6kW of solar PV on the roof (make sure your roof is designed well, to accommodate north, or east/west facing panels). RC AC to heat/cool the home. Plus fans to cool (way less energy usage). Evaporative cooling is cheap to run, but only good in very dry climates, not Melbourne. Heat pump or electric element domestic hot water (powered by solar PV). Induction cooktop. Gas bottle for the BBQ. As for your initial questions. Splits are more efficient than ducted (due to energy losses in the ducts). So I'd be looking at splits, maybe multi heads, & maybe a single head or two, whatever fits. I believe single head are usually more efficient? Hey ddarroch - am also looking to do a new build in Donnybrook (VIC 3064) and have been recommended "Solaray" to do a roof solar panel install (with EnPhase brand microinverters) and a Tesla PowerWall2. Any other installers you would recommend that would service the Kalkallo / Donnybrook area? Hey Tesla, How r u getting the solar installation done with the initial build?? Cheers, Hey - I think the only way is after the house is built fully and then landscaping & fence & driveway is completed, then I have to call "Solaray" and start the process? This is what I have been told here and there by some. Happy to be corrected if there is a quicker/cheaper/better way and if the actual house builder [eg: M , B , PD] can take care of it during the build phase Tesla Tom ('Ludicrous Feed') [click here for YouTube link] and Adam ('Tesla Straya') [click here for YouTube link] used 'Solaray' for their roof solar panel install, and here is the Solaray youtube click link By the way, which estate are you building in (Platform, Kinbrook, Donnybrae, Peppercornhill, Olivine)? Is there an issue with the Donnybrook area having rocks underneath and an extra AUD$15,000 - $20,000 has to be spent on top of the titled land purchase cost? Read about the rock issue on this forum (click here for direct post link) Re: Electricty & gas -- for my build some involved in the purchase are insisting that gas cooking is a must, but I personally am of the view that 'electric cooking' is sufficient with an electric water heating system that will be powered off the solar panels & the grid if/as required, and installing gas will be extra costs and also cost more money with maintenance over the next 10-15 years compared to electric cookstop & water heating. Would also like to hear your recommendation for a conveyencer lawyer (whose law practice has a trust account) that you perhaps used for your Donnybrook land purchase / section 32 paperwork transaction. Re: New Build - Ducted Refrigerated OR R/c Multi Splits OR R 19Jan 01, 2020 10:31 am Well, we are waiting for the stage 10/11 land release at Olivine. We've visited Donnybrae & Kinbrook. Kinbrook - everything was good until I discovered that the only network option would be Opticom fiber - which is a huge deal breaker. Not to mention the potential noice restrictions etc. Due to the railway line & the increase in cost. Donnybrae - All good except for the high price & the fact that they're piggybacking on the infrastructure given by Olivine, Merrifield & Cloverton. So I just couldn't stop feeling as if I'm getting ripped off lolz. Platform - Apparently there's some sort of a litigation issue going on. Nothing that I know for sure but smoke is almost always followed by fire. So don't want to take a chance. Re: New Build - Ducted Refrigerated OR R/c Multi Splits OR R 20Jan 01, 2020 10:36 am AFAIK Donnybrook & the surrounding area is on volcanic rock or whatever the geologists call it So rocks are to be expected, it depends on your luck whether you'll end up with a block that has a friggin huge boulder underneath or not. Boutique mentioned that the biggest they've charged in around Donnybrook was $20k (fixed site costs). So when I'm doing finances I'm planning for an additional $22k Hopefully it won't be that much Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 0 6295 |
