Browse Forums Building A New House Re: Perth Project Builders M2 Pricing 2Dec 14, 2019 12:16 pm Gee that seems almost unrealistic ,280,000 for a custom build,there has to be some big surprises somewhere or lots left out and or doubtful quality ,ask plenty of questions and check how possible or realistic the price given is. Re: Perth Project Builders M2 Pricing 3Dec 14, 2019 12:59 pm Joker Gee that seems almost unrealistic ,280,000 for a custom build,there has to be some big surprises somewhere or lots left out and or doubtful quality ,ask plenty of questions and check how possible or realistic the price given is. When I say custom build it is one of their advertised plans but heavily altered to suit. One of the builders is probably the biggest in W.A and the others are well known so I will be checking the fine print dont worry but it seems everyone is keen for your buisiness at the moment. Re: Perth Project Builders M2 Pricing 5Dec 14, 2019 1:35 pm Brett0004 Joker Gee that seems almost unrealistic ,280,000 for a custom build,there has to be some big surprises somewhere or lots left out and or doubtful quality ,ask plenty of questions and check how possible or realistic the price given is. When I say custom build it is one of their advertised plans but heavily altered to suit. One of the builders is probably the biggest in W.A and the others are well known so I will be checking the fine print dont worry but it seems everyone is keen for your buisiness at the moment. Re: Perth Project Builders M2 Pricing 6Dec 14, 2019 2:19 pm Joker Brett0004 Joker Gee that seems almost unrealistic ,280,000 for a custom build,there has to be some big surprises somewhere or lots left out and or doubtful quality ,ask plenty of questions and check how possible or realistic the price given is. When I say custom build it is one of their advertised plans but heavily altered to suit. One of the builders is probably the biggest in W.A and the others are well known so I will be checking the fine print dont worry but it seems everyone is keen for your buisiness at the moment. Really worth getting a pre contract inspection with a highly qualified inspector, mistakes, oversites ,unfair builder friendly clauses will be picked up,good luck. Good advice, will do. Thanks Re: Perth Project Builders M2 Pricing 7Dec 15, 2019 9:03 am chekii I would say $880 psqm is quite low and would be the very basis cost. What type of specs is the builder offering? Chekii in regards to specs as far as I can see specs between Perth "project" builders are similar across the board, I agree there will be a variance due to the trades people they use but concrete slab, double brick and framed timber roof seems to be how its done. Sure some use verticore and some dry wall internal bricks and there are pro's and cons to both, Some dry wall and others hard finish plaster. Roofs are framed with blue treated timber and 450 centered ceiling joists. I think more of the "Spec" comes with what you choose during fitout. All offer melamine cupboard carcases and engineered stone tops. A mix of Laminex or Formica door options and tapwear you can option up. As a sparky I have requested 3 phase mains and conduits down all walls. I have taken out any fancy light packages. All come with a fully ducted name brand zoned air conditioner suspended in the roof space. I have specified how waterproofing to wet areas is done, tiling to be mitred, front door 1200 wide and Delf linear handles, 28 coarse doors and frames throughout, Porcelain rectified 450 tiles and carpets to bedrooms (will see what is allowed for) Insulation R4 to entire house, and cavity insulation to west facing walls. Windows and frames seem to be all Jason or similar. Plumbing fitout is a bit of a mixture but will check prior to signing. I have requested 2 off instantanious gas water heaters located adjacent to wet areas. I have removed all paving and will organise my own. Site works which is provisional with all covers concrete soak wells (will check quantity) crossover, block survey, skim, etc. I will check all service connections are covered. The prices given are all the first stage roughys and not the hard line sit down and sign prices so that will be interesting. I have a fairly long check list so I will be going through it and itemising. Will see how we go !! Interesting times. Re: Perth Project Builders M2 Pricing 9Nov 14, 2020 12:17 pm Just an update on an old post, well its nearly finished and it has been a smooth process so far and at a good price. These photos are a few weeks old so its closer to being finished now. FrontLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ RearLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ KitchenLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Guest EnsuiteLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master Ensuite ShowerLike ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Perth Project Builders M2 Pricing 11Nov 14, 2020 2:34 pm Just for clarity. What did you end up paying total for the house? Your original costings seemed very cheap. Fortunately you built at just the right time. I wouldn't want to be building now. The price is up and quality will be down. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Perth Project Builders M2 Pricing 12Nov 14, 2020 3:27 pm chippy Just for clarity. What did you end up paying total for the house? Your original costings seemed very cheap. Fortunately you built at just the right time. I wouldn't want to be building now. The price is up and quality will be down. Was originally 291k, we upgraded the kitchen bench top to level 3 stone which added 7k. There is no way we would have got it for that now, that was signed up at the bottom of the cycle. Sure we missed out on all the Govt subsidies but I feel that we are miles in front, also your right I think we have had very good tradies as well on our job as well as a resonable timeframe. Slab was poured May 30 and basically finished in 2/3 weeks time. Re: Perth Project Builders M2 Pricing 13Oct 06, 2021 7:08 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅
Just to close off an old thread of mine here is it now ten months after we moved in. Still absolutely thrilled with our new home. Not so thrilled about how much yard to sort 1 2745 DIY, Home Maintenance & Repair That laser level looks lovely! We bought one for less than a quarter of that price off eBay. It worked really well for us and it's still going now, five years later. After… 1 16963 |
