Browse Forums DIY, Home Maintenance & Repair 1 Dec 11, 2019 11:31 am Hi, There is a small gap which has appeared between wardrobe and wall as shown in picture. Can i cover it somehow, don't want to screw in the wall because there is live wire near by. Can i get some kind of fancy tape/filler/moulding from Bunnings/ebay to cover it. Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Cover gap between wardrobe and wall 2Dec 12, 2019 8:10 pm the cupboard has bowed. Very good chance the wire for the switch is running up the wall. Remove the with plate to check, then screw below. 2 7553 Normally you use builders bog. Polyurethane painting is basically the same principle as car panel beating and painting. All the prep work is the same and so is the… 3 3084 Probably a not bad thing to mention particle board should in case anyone else reading this got the two confused. 6 4915 |
