Browse Forums Building A New House Re: New Home construction slab crack 4Dec 12, 2019 11:23 am John0322 Hi All, Our Frame and Truss have been erected. And I noticed a hairline crack that goes from one side of the house to the other. Below is a photo of a segment of it. I'm just wondering if I need to worry about it or have it mended? I did notice that on one side the crack has started from a nail on the frame. Thank you for looking Below is the link for the full walkthrough video of the crack. Should I get a building inspector to check or a Structural engineer? https://photos.app.goo.gl/cngWYDDVEVbyqwo77 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ If you are worried about this I'd steer clear of ever looking at your future garage floor 18 months from now. It's nothing. Re: New Home construction slab crack 5Dec 12, 2019 11:31 am Mr. Sausage John0322 Hi All, Our Frame and Truss have been erected. And I noticed a hairline crack that goes from one side of the house to the other. Below is a photo of a segment of it. I'm just wondering if I need to worry about it or have it mended? I did notice that on one side the crack has started from a nail on the frame. Thank you for looking Below is the link for the full walkthrough video of the crack. Should I get a building inspector to check or a Structural engineer? https://photos.app.goo.gl/cngWYDDVEVbyqwo77 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ If you are worried about this I'd steer clear of ever looking at your future garage floor 18 months from now. It's nothing. Thank you, that's comforting. I primarily worry if it has structural consequences because the crack spans the entire width of the slab (as in the video link on my original post). And if it needs to be fixed then it has to be done now than later before the floor and wall coverings are installed. Re: New Home construction slab crack 6Dec 12, 2019 6:38 pm Looks like you need to talk to the builder, he will probably say it's normal but because it goes the entire width, Id want it looked at by a third party. Re: New Home construction slab crack 7Dec 12, 2019 10:25 pm Nothing to worry about! It's common. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 9317 I can help you with all that, you can PM me with details if you wish 3 5852 The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 19108 |
