Browse Forums Building A New House Re: First Home Build - Mount Barker 15Dec 09, 2019 10:00 am Fingers crossed that your construction footing report comes through quickly, ours took just over 4 weeks. If you havenโt already visited the Design centre, then call in a few times to check it out before your selections appointment. It opens on Saturday mornings too, which is helpful. You can easily spend an hour or more taking it all in. Take photos of everything you like in the Design centre, and then check the cost in your Selections booklet, which you should be getting soon. It gives you an idea of how much your upgrades costs are likely to be before you go to your appointment. Best of luck. ๐ If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8318 So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27739 hi guys. Please be nice. First time home builder in Qld. I would like some feedback please on whether I should build my granny flat first before my main house at the… 0 4597 |
