Browse Forums General Discussion Re: Windows - is it worth upgrading with project builder 2Dec 05, 2019 11:21 pm Project builders windows sometimes don't have rollers only plastic slides that you need to spray with silicone spray, if yours have these, upgrade if you can. Just a thought Re: Windows - is it worth upgrading with project builder 4Dec 06, 2019 1:25 pm Yes, wide and substantial window frames can make an even cheaply built home look like it has been well built, whereas thin and flimsy window frames can cheapen even a substantial home. However, the idea is not just to make the windows look better, ideally, the first priority is comfort and performance, and then the consumer typically finds that any system which offers high performance is also visually stunning, design wise. Sydney Double (and now Triple) Glazed Windows and Doors mob 0412 717 066 Sydney, Canberra, Newcastle, Wollongong www.doubleglazedwindows.net.au As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is… 3 28029 Hi all, Been browsing project builders' website and saw Masterton with attached granny flat design Seeing bad reviews from masterton in this website/facebook, does… 0 18897 VERY important to understand that each franchise is a independent business, so there are bad franchises out there as well as good (no different from a Bakers Delight… 4 2782 |
