Hi All,
I have bought a lot in Clydesdale Estate. Didn't see any topic/discussion on that estate.
Any one else bought in that estate in this forum?
-shiraz
Browse Forums Building A New House Re: Building at Clydesdale Estate Marsden Park 6Dec 03, 2019 12:48 pm Hi Shiraz, I have a lot of Waffle Pod used in Marsden Park. I just want to know if you and other land buyers are aware of the consequence of flood, sever flood and rain in your area and is your foundation covered under the lifetime structural warranty. Will Council who is asking for H1 Slabs compensate you for damages. Will your insurer after 7, 8 or 10 or 15 years compensate you for foundation failure. The soil is test by Developer in acreage and not in square meter. So you cannot and Council should not rely on Landcom or other Developer soil testing. If you builder has done one then again it can fail because there may be no house around your Lot. What others do for lawn and gardening that may impact in future as well as what happens to rain water will depend in the future. I would ask for conventional slab which should be part of base price. I think new Lot owners must hold meeting to discuss the near future danger. As you know many buyers you might want to share these information. https://www.youtube.com/watch?v=yUZMjLt0q2A https://www.youtube.com/watch?v=fEVmCcUQZt8 Re: Building at Clydesdale Estate Marsden Park 8Dec 08, 2019 9:21 pm Ronnal This is our builder's reply to the slabs. The standard slab for your home right now is an SD4 slab. Its already over engineered for our quality homes. This is half way between a H1 and H2 slab, should the design engineer specify that we need a different slab, this will be no charge for you as it’s a fixed site cost for your project. These slabs are already 100mm thick compared to the 86mm thick from most builders M class. The steel reo is also 82 SL mech compared to 72 standard mesh. What do you think of this? Re: Building at Clydesdale Estate Marsden Park 9Dec 10, 2019 3:56 pm Onram @Ronnal This is our builder's reply to the slabs. The standard slab for your home right now is an SD4 slab. Its already over engineered for our quality homes. This is half way between a H1 and H2 slab, should the design engineer specify that we need a different slab, this will be no charge for you as it’s a fixed site cost for your project. These slabs are already 100mm thick compared to the 86mm thick from most builders M class. The steel reo is also 82 SL mech compared to 72 standard mesh. What do you think of this? Hi Onram, The Builders will try to attract you as much as they can. There is a case of Metricon in 2008 which was resolved in 2011 and Australian Standard reviewed on Waffle Pod in 2011. Since then nothing nothing happens as we are stuck in drought. Here are some links for you. https://www.youtube.com/watch?v=fEVmCcUQZt8 https://supagroup.com.au/blog/waffle-slabs/ https://www.cornellengineers.com.au/beware-waffle-slabs/ https://www.slatergordon.com.au/media/waffle-slab-warning-for-melbournes-western-suburbs https://www.youtube.com/watch?v=crcs-Z5SYcU https://www.theage.com.au/national/victoria/thousands-of-suburban-home-owners-facing-financial-ruin-20140607-39q4z.html Re: Building at Clydesdale Estate Marsden Park 10Dec 10, 2019 4:00 pm Hi Onram, You can ask for Conventional Slab if there is no charge. You will live in the house and your grandchild can demolish the building above the slab and they can reuse the Conventional Slab. https://www.youtube.com/watch?v=v1xz3v7j5bA Re: Building at Clydesdale Estate Marsden Park 11Dec 10, 2019 4:05 pm Hi Onram Look at the link about home building on youtube. I am also learning from this for my new home. https://www.youtube.com/results?search_query=+Beowulf+Builders+Pty+Ltd there are Private Builders such as AA Rapid Builders etc but I would research about private builder on NSW Fair Trading before I do anything. https://www.onegov.nsw.gov.au/publicregister/#/publicregister/search/Trades Not only you must check on Builders but also on Directors, Supervisors and Site Managers. I would only enter a fixed price contract for both Private (small scale builder) as well as bigger builders. I WOULD NOT ENTER THE CONTRACT AS OWNER BUILDER. DO NOT ENTER AS OWNER BUILDER. Re: Building at Clydesdale Estate Marsden Park 12Dec 12, 2019 12:07 am Ronnal : Who are you building with? We're entering the contract on Home & Land package, not owner builder. As for the slabs, a quick google of SD4 slabs and I couldn't find much information regarding this type of slabs which is concerning. I have no experience in building so I am quite curious on this. StructuralBIMGuy, do you know anything about SD4 slabs? Re: Building at Clydesdale Estate Marsden Park 13Dec 12, 2019 8:49 am Onram @Ronnal This is our builder's reply to the slabs. The standard slab for your home right now is an SD4 slab. [i][b]Its already over engineered for our quality homes.[/b][/i] What do you think of this? Most builders use different names and I can only guess... its becomes difficult to compare ? I often hear my AB4 is better than their XC3 ? Unfortunately, SD4 without reference to the Standards means nothing without the details and engineering stamp/certification. I suggest you get a signed copy before you handover any deposit and have it properly checked out if you are unsure Onram This is half way between a H1 and H2 slab, should the design engineer specify that we need a different slab, this will be no charge for you as it’s a fixed site cost for your project. It's only fixed once the contract is signed and siteworks have commenced Until they start eg level etc all bets are off Onram These slabs are already 100mm thick compared to the 86mm thick from most builders M class. The steel reo is also 82 SL mech compared to 72 standard mesh. What do you think of this? All Class M Slabs are 100mm thick as per the codes AS2870 85mm Slabs are non compliant, but some builders get away with them? They don't get away with it if the slab pour is inspected by an Engineer The slab mesh size is a function of the slab size/dimension There are other factors ie internal Beam, size, position,reinforcement,etc Of course all Builders will tell you we do it better..that is part of the sales process. Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Building at Clydesdale Estate Marsden Park 14Dec 12, 2019 9:02 am Ronnal Hi Onram, You can ask for Conventional Slab if there is no charge. You will live in the house and your grandchild can demolish the building above the slab and they can reuse the Conventional Slab. https://www.youtube.com/watch?v=v1xz3v7j5bA It's a good video with some helpful Info But what is missing is the engineers inspection and certificate That is required in WA Also in WA we put down a thick certified sand pad Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Building at Clydesdale Estate Marsden Park 15Dec 13, 2019 12:37 am StructuralBIMGuy This is the builder's reply when I asked about SD4, fixed site cost, and using conventional slabs. We don’t even reverse build our homes like all the other builders so we could get a better quality home as the end result. Attached is our slab grades from SD1 – SD6, you can send this to your engineer to research on. Our site cost are fixed for your site, as also explained on your tender. This is why most of our clients are referred by friends and family who has already built with us. After your plans are approved by council, your plans will go through final engineering to get your “CC” Construction certificate. Even if you need any upgraded slab, this will be part of site cost. Nearly all builders use M class for standard and H1 if its saline soil affected. M class is 85mm think most times depending on the final engineering specs. That’s why not many knows about SD4 100mm besides a few high end builders. And NO, we will not use standard slabs (conventional slabs) for our homes as per your request, we are a high quality builder and will not use anything less than a SD4 system. Attached is the files they sent to me. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building at Clydesdale Estate Marsden Park 16Jan 09, 2020 11:17 pm Ronnal Hi Onram, You can ask for Conventional Slab if there is no charge. You will live in the house and your grandchild can demolish the building above the slab and they can reuse the Conventional Slab. https://www.youtube.com/watch?v=v1xz3v7j5bA Hey Ronnal - this is a very informative thread and appreciate your contribution Re: Building at Clydesdale Estate Marsden Park 18Jan 29, 2020 11:14 am Onram Just got the email from builder that the land registration for Clydesdale Estate may be delayed. Anyone got this too? Hi Onram, My builder has also just told me that it might get delayed. Have you received any confirmed date? The real estate agent I purchased the lot from isn't available. Do you know how to contact the developer? Thanks, Shiraz Re: Building at Clydesdale Estate Marsden Park 19Jan 31, 2020 7:02 pm shiraz. Onram Just got the email from builder that the land registration for Clydesdale Estate may be delayed. Anyone got this too? Hi Onram, My builder has also just told me that it might get delayed. Have you received any confirmed date? The real estate agent I purchased the lot from isn't available. Do you know how to contact the developer? Thanks, Shiraz Hi Shiraz, The builder just told me that it would be approx in September 2020.. I'm not sure how to contact the developer, I will try this weekend. Re: Building at Clydesdale Estate Marsden Park 20Feb 02, 2020 12:52 pm Onram shiraz. Onram Just got the email from builder that the land registration for Clydesdale Estate may be delayed. Anyone got this too? Hi Onram, My builder has also just told me that it might get delayed. Have you received any confirmed date? The real estate agent I purchased the lot from isn't available. Do you know how to contact the developer? Thanks, Shiraz Hi Shiraz, The builder just told me that it would be approx in September 2020.. I'm not sure how to contact the developer, I will try this weekend. I called the 1300 number available on Clydesdale website. The guy just told me that registration has been delayed until Sept 2020. Didn't provide much details. Let me know if you find out more. Thanks, Shiraz |
