Browse Forums Building A New House Re: Setback rules for this corner block 10Nov 22, 2019 11:13 pm I think part of the issue here is that you do not have a corner block, and trying to apply corner block rules here will get you nowhere. You have essentially what is known as a battle-axe lot. You are relying on the driveway past your two neighbouring houses to get to your house (that's the handle of the battle-axe). Some guidelines would say that you actually have 3 side boundaries and 1 rear boundary (which kinds sounds confusing in itself), but that basically means that you do not need to be level with the neighbour's house. You do need to be set back a bit from the 43m boundary though. My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 hey nedket, We have a similar lot like yours . just wondering how is it going with your DA application, is the Blue line is the correct solution (offset the rear boundary… 1 9472 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3899 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 16160 |
