Browse Forums General Discussion Re: Plumbing washing machine into rainwater tank? 3Nov 22, 2019 2:53 pm meminiau Hi all I've been thinking about plumbing the waste pipe from my washing machine into our rainwater tank. If I only use the tank water for the lawn and toilets, does anyone see me having an issue? The only one that comes to mind is whether or not the washing machine pump is strong enough to pump the water high enough to into the tank. Thank in advance! Real bad idea. You cannot store grey water for more than 24 hours. The washing machine pump is not suitable. Just use the final rinse on the garden and also plumb more downpipes to the tank but make sure that the tank is not in risk of overtopping during heavy rain. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Plumbing washing machine into rainwater tank? 4Nov 22, 2019 7:07 pm We had our communal laundry use the rainwater tank that switched over to the normal water when the water got below a certain level in the tank. The problem. Our Climate. Due to lack of constant rain turnover, tank water would go 'stale' and leave people's clothes with a nasty after smell. We had to abandon it and just leave the tank for the lawns. Re: Plumbing washing machine into rainwater tank? 5Nov 22, 2019 7:56 pm dav2708 We had our communal laundry use the rainwater tank that switched over to the normal water when the water got below a certain level in the tank. The problem. Our Climate. Due to lack of constant rain turnover, tank water would go 'stale' and leave people's clothes with a nasty after smell. We had to abandon it and just leave the tank for the lawns. The rainwater harvesting system was obviously sub standard. If a rainwater harvesting system is competently designed and plumbed, the water will be sweet and not become anaerobic. Unfortunately, most (I estimate +95%) water tank installations are sub standard (and overpriced). 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the… 0 17520 18 90478 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31280 |
