Browse Forums Building A New House Re: Clarendon Boston 34 design considerations 6Nov 21, 2019 6:53 am amilelka You could mirror the plan so that the guest room and theatre can have windows facing North. You could then add an extra North facing window to your master bedroom as well. A West facing bed room will get hot, but like you said you can add a balcony, e- glass and curtains to mitigate. Catching sunset views from a master bedroom can be quite nice. When you’re constrained in having a relatively small block of land, and if this is the house design you really like, then I agree with these comments of mitigating the summer heat as best you can by using low e-glass and perhaps extending the eaves. Build your house, live in it for a summer and if the heat is a problem, fit an external roller shutter. Best of luck with your build. Re: Clarendon Boston 34 design considerations 7Nov 22, 2019 9:50 am Thanks for all the suggestions and comments. I’m fairness I knew the limitation of the block when purchasing and I would be unable to mirror designs. I’ll discuss my concerns with the builder and see what changes can be made. the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 6731 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 13639 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7855 |
