Browse Forums Building A New House Re: Clarendon Boston 34 design considerations 5Nov 21, 2019 6:39 am Dmcintyre85 Hi All, Looking at some guidance regarding layout and orientation of my new build. I have read a number of articles however it seems the more I research the more confused I become. It’s my first build. Below is a proposed layout. I have not yet signed a tender. I have crudely marked Magnetic North in blue. Basically rear faces East and Front West if I understand Solar/True North. I am looking for input, I have some concerns have the main bedroom facing West. I have the option to move main bedroom to rear of house but it has a knock on effect to rest of layout which I am trying to avoid. Should I be overly concerned with main bedroom facing west? I have read I can add double glazed windows, facade with balcony and larger eves etc Also curious if I will have enough natural light throughout the house. I plan to discuss with Clarendon however wish to be armed with some information prior. Anything else that I should be concerned about Land is in Elara, Marsden Park. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ You should be overly concerned that the main bedroom is West facing, its the worse possible way to face a bedroom. Anyone giving advice otherwise has no idea, seriously, who wants to go to bed after the West setting sun has heated your room to 30 degrees plus? Yes you can run air conditioning but it will be going pretty hard every summers evening. As for adding extra north windows to a bedroom, wow, just wow. Sorry but if you can’t flip that design it’s not suited to that block. Ridiculous that developers and councils can create a situation where they force someone to have their garage on the North side of their block due to poor planning. Idiots. Re: Clarendon Boston 34 design considerations 6Nov 21, 2019 6:53 am amilelka You could mirror the plan so that the guest room and theatre can have windows facing North. You could then add an extra North facing window to your master bedroom as well. A West facing bed room will get hot, but like you said you can add a balcony, e- glass and curtains to mitigate. Catching sunset views from a master bedroom can be quite nice. When you’re constrained in having a relatively small block of land, and if this is the house design you really like, then I agree with these comments of mitigating the summer heat as best you can by using low e-glass and perhaps extending the eaves. Build your house, live in it for a summer and if the heat is a problem, fit an external roller shutter. Best of luck with your build. Re: Clarendon Boston 34 design considerations 7Nov 22, 2019 9:50 am Thanks for all the suggestions and comments. I’m fairness I knew the limitation of the block when purchasing and I would be unable to mirror designs. I’ll discuss my concerns with the builder and see what changes can be made. the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 6815 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 13706 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7938 |
