Browse Forums Building A New House Re: Setback rules for this corner block 9Nov 20, 2019 4:23 pm Koda67 TuffNutt Koda67 5 meters from the end of the crossover for the garage, 4 meters to the start of the build line for the home. Provide that you are going to place abutting with the 17m boundary. Which I'm not. No one seems to know the rules if I'm abutting with 43m boundary. Okay no problem. You will then have to comply with the same setback as the home on the 43m boundary. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is from the VBA website under part 5 - Building Regulations - Setback. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Based on this rule, my setback can't be more than 1/3 of lot depth (depth is 43.3m on east side and 41 on west side). So if I were to take 1/3 of 43.3 then my setback can't be more than 14.4 which will encroach on my neighbour by at least 2m. If I were to abide by neighbour's setback, my setback from the front of the lot will be almost 17 meters. Fwiw, I spoke to the city council again and they said they don't have an answer for me. They told me the only way to get a definitive answer is to apply for site dispensation, at that point they will study the sitting plan and make a decision. Re: Setback rules for this corner block 10Nov 22, 2019 11:13 pm I think part of the issue here is that you do not have a corner block, and trying to apply corner block rules here will get you nowhere. You have essentially what is known as a battle-axe lot. You are relying on the driveway past your two neighbouring houses to get to your house (that's the handle of the battle-axe). Some guidelines would say that you actually have 3 side boundaries and 1 rear boundary (which kinds sounds confusing in itself), but that basically means that you do not need to be level with the neighbour's house. You do need to be set back a bit from the 43m boundary though. My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8462 This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3674 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15778 |
